![]() | Home > Technical (L322) > passenger door will not lock |
You need to replace the latch assembly sir, the C/L motor is part of the latch and when they fail you loose one function at a time...
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 ![]() ![]() ![]() |
Thanks for the reply,so it looks like more$$$. Is this a big job or just plug and play? |
Door card off, remove 3 torx bolt fixings, unplug the elec plug, slide it out and the opposite to refit!
