![]() | Home > In Car Electronics (L322) > Bluetooth ULF stopped working |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Hi all.
Found the problem. Pin has broken off in the ULF. Looks like a bit of corrosion. Pin 17 (red/yellow cable). |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
That'll be the power pin then....
I opened up the ULF but the socket is soldered to the pcb and has some kind of cover around it and I can't see how to get this cover off to access the base of the socket. I planned on soldering a small cable to the point on the pcb and taking the cable out the side of the ULF to the plug, bypassing the socket.
