Home > Maintenance & Mods (L322) > Brake discs
Lanby
2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Brake discs
I'm looking at purchasing a new set of discs and pads for my missus 2012 car and have not decided on genuine or aftermarket parts yet, but the question is if I use genuine can anybody recommend which paint would be good to stop them going rusty?
Post #321605 7th Apr 2015 11:55am
defo get genuine from dan @ duckworths..
any heat resistant paint like paint for barbecues etc.. ... - .- -.
Post #321607 7th Apr 2015 12:03pm
Lanby
Never thought about BBQ paint, cheers
Post #321615 7th Apr 2015 12:56pm
Rangeyman
Am sure you cannot go wrong with genuine but I think this is one of those occasions where you really do have a choice,there are plenty of discs out there with far better performance than genuine and lots of good makes that are well trusted, well made and are up to the task that may be a little cheaper than genuine,just don't buy cheap Censored !!
Post #321667 7th Apr 2015 5:37pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I ordered genuine from Dan at Duckworths and then painted hub and vents with high temp aerosol paint off ebay nearly two years ago. It has really stood the test of time, including a very high temperature trauma with a sticking caliper.
Well worth the effort.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated :mrgreen:  2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 L322 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #321674 7th Apr 2015 6:36pm
I always paint mine in Engine Enamel spray paint and its brilliant long term sir Thumbs Up
Post #321699 7th Apr 2015 8:54pm
tafftoo
2006 Range Rover Supercharged 4.2 SC V8 Java Black
I've just ordered a set of Brembo Pads and Discs from Advanced Factors. Decent price too Smile
Post #321920 9th Apr 2015 1:49pm
wealy
I wouldnt contemplate anything but genuine.
Post #321926 9th Apr 2015 2:09pm
Lanby
I'm assuming you have to have Brembo callipers to fit Brembo discs/pads?
Post #321931 9th Apr 2015 2:31pm
tafftoo
I would think so, but mine does have the brembo calipers so it makes sense for me Smile
Post #321935 9th Apr 2015 3:09pm
Lanby
Right, I've decided - Genuine parts from Dan at Duckworths, paint them with HT paint (probably ebay grey).
One last question, I've just bought a torque wrench, does anybody know the disc bolt torque settings?
Cheers
Post #321936 9th Apr 2015 3:28pm
tafftoo
If you're talking about the torx screw that holds the disc on, I believe it's 35nm.
Post #321958 9th Apr 2015 5:07pm
Rangeyman
A quick look online and you can find great quality discs from Ebc,mintex,Bosch,Britpart,Quinten hazel,Brembo all at prices similar if not better than genuine and some are painted that will last the lifetime so no need to paint,if you want to spend a few extra quid you will get much better slotted/drilled .Or you could be safe and choose Genuine!
Post #321972 9th Apr 2015 7:34pm
Lanby
tafftoo, I was being a spaz, I meant the wheel bolt torque figures!
Post #321995 9th Apr 2015 11:31pm
140nm, 103lbft for wheel nuts.. ... - .- -.
Post #322003 10th Apr 2015 7:23am
