![]() | Home > Technical (L322) > Took the plunge and fitted new alternator. |
bpp1980 Member Since: 21 Apr 2013 Location: Melbourne, Australia Posts: 30 ![]() ![]() ![]() |
Nice work |
krisleeds Member Since: 19 Oct 2014 Location: leeds west yorkshire Posts: 60 ![]() ![]() ![]() |
All i did was keep an eye on the voltages over a couple of days. I had all sorts of wierd electrical problems. I thought once an alternator went, it went completely but my freind says thats not always the case. One day it was fine at 14.7v, Then the next it would stick at 13v and if i loaded it up by switching everything on it would drop to 12v and not move when revving. Now it drops to 12.5v and shoots right up to 14.7v at 2000rpm with it all loaded up. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8110 ![]() ![]() ![]() |
You've done the right thing - if you do a search, there have been loads of problems with 2007 TDV8 alternators |
^ yep... I'll attest to that |
Thanks. Yeah loads of things pointing towards alternator. Its at 82000 miles which apparently is common for them to go at this mileage. Bought a denso unit from euro car parts. |
crispy2 Member Since: 18 Aug 2013 Location: Mandurah Posts: 102 ![]() ![]() ![]() |
Is the 2007 TDV8 alternator problem prevalent with the 2007 Supercharged? I've not heard of it being a problem (with the S/C) but keen to know if it is confined to the TDV8.
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Nice job Kris...let me know if you need any codes resetting |
Yeah will do paul. Thanks for all your help. |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 226 ![]() ![]() ![]() |
I have just replaced mine. It had developed a whine, but I could not detect any problems whatsoever, but I was pretty sure it was the alternator.
