Home > Technical (L322) > Turbo cut in point
scanner
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
Turbo cut in point
I'm just about to get my RR (Whopee Razz Razz Razz ). It's a 2010MY TDV8 Vogue. At what engine speed does the turo cut in?
Presumably if I drive at just below that level on long M-way journeys it will reduce diesel consumption Question
Post #32231 18th Oct 2010 1:43pm
you've just spent loads on a FFRR and you're worrying about fuel consumption.... Shocked ... - .- -.
Post #32237 18th Oct 2010 2:20pm
scanner
Look where I'm from, it explains everything Rolling with laughter Rolling with laughter Rolling with laughter
Post #32239 18th Oct 2010 2:31pm
Re: Turbo cut in point
When you turn the key..................
Post #32240 18th Oct 2010 2:32pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
As Scarey says, forget worrying about MPG. If you are doing a long long haul then sit back and enoy the car's comfort, set the cruise at 70 and let it pur along at 1850rpm and it should settle down on the average mpg setting at somewhere in the region of 29-30mpg, a bit less if there are a few hills to climb, a lot better if it is flat lands you are driving. Just don't try to drive it like a GTi, then you will get low to mid 20's - leave GTI driving to the Saxo boys. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #32246 18th Oct 2010 3:37pm
scanner
My question wasn't purely about fuel use. I seem to remember many years ago when I had an Isuzu Trooper which was turbocharged. When accelerating it made a pleasing noise as the turbo cut in and you seemed to feel the extra push. Since then I've driven diesel Beemers so have forgotten all this turbo stuff.
Can't wait to pick it up Thumbs Up Thumbs Up
Post #32265 18th Oct 2010 5:42pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
scanner wrote:
...Can't wait to pick it up Thumbs Up Thumbs Up
You will love it scanner! Cool Thumbs Up
Post #32271 18th Oct 2010 6:14pm
iT LAD
What colour combo have you opted for...
Post #32281 18th Oct 2010 6:33pm
delamo
Stornoway Grey, Charcoal Leather and Factory tints I think iT LAD Whistle
Post #32284 18th Oct 2010 6:40pm
It's a miss conception amongst drivers that boost is bad for fuel consumption. The reality is that without boost engines have to rev harder, and more of the fuel they burn is used to turn the engine than develop power.
In the 80's Ayrton Senna's fuel consumption was higher than Alain Prosts because he thought it was better to have higher revs and lower boost. The Honda engineers told him otherwise and he altered his driving.
In the battle of Britain pilots used to reduce the boost of their superchargers as they thought it would save more fuel than reducing revs. But the power of a Merlin engine at 3000rpm would be absorbed by the engine, supercharger and propellor at roughly 20%, 10% and 70% respectively. At 2000rpm that's 10%, 5% and 85%. Subsequently the RAF printed leaflets with the rather quaint 'Reduce the revs and boost the boost, you'll have enough petrol to get home to roost'.
If you look at the latest 4.4, it has quite a small turbo for its size, and 8 quite long gears. The idea is to get boost at very low revs so the engine can turn slowly but still develop enough torque to work. At higher revs it has another turbo to provide boost at bigger volumes.
So the answer, is let the engine slog in a lowish gear with the turbo going at full pelt.
...if you can in an automatic.
Post #32305 18th Oct 2010 8:54pm
scanner
Zermat Silver with Jet Oxford leather. No tints, don't do enuogh drugs for that Embarassed
Post #32552 20th Oct 2010 5:14pm
