Home > Maintenance & Mods (L322) > Auxiliary switch panel
For any of you wishing to fit extra switches for whatever reason, this is my solution.
I was looking to fit then in the front fascia panel but that was going to be a right a Censored e of a job so I came up with this.
Surprisingly very straight forward to do.
Decided to fit a couple of decent map reading lights whilst I was at it.
Post #322563 14th Apr 2015 12:57pm
tidy job Thumbs Up ... - .- -.
Post #322566 14th Apr 2015 1:08pm
Neat job! Thumbs Up
Do you mind me asking where you got your switches from? Si. <This is my name.
Post #322567 14th Apr 2015 1:08pm
ebajema
What sort of power supply do you have up there ?? Ignition positive and/or permanent positive ??
Would be a great powersource for a dash cam for example and a great place for a switch to switch it on and off. MY 2010 5.0 SC Galway green and sand interior!!
Post #322568 14th Apr 2015 1:10pm
@Bellini
These are the switches as recommended by stan,
http://www.ebay.co.uk/itm/Square-Panel-Mtg...rmvSB=true
@ebajema
I ran a new 10A power supply and earth and some spare cables from below the front fuseboard by removing the roof console, unpicking a small edge of roof trim above the passenger door, feeding a stiff piece of wire through the roof space to the console position, connecting a number of wires to the end of the stiff wire at the console end and then pulling back the stiff wire out of the roof with the cables attached. Ran the new cables behind the roof trim and then down behind the A post cover and then into the end of the dash by removing the end panel.
This then allows you access for the cables below the fuseboard to do with as you chose. Sounds complicated but was very straight forward.
Post #322570 14th Apr 2015 1:26pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Nice job Thumbs Up , I was going to fit a switch on that pannel for the rear camera but was'nt happy with it there, loads of space up there for switches. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #322572 14th Apr 2015 1:37pm
i hope you dont mind me hijacking your thread Dave but here's my setup,
closed,
open,
Post #322576 14th Apr 2015 1:50pm
Very neat stan but as you'll appreciate the TD6's aren't fitted with the convenient flap covered holes of later models.
I'll bear that in mind for the future Wink Thumbs Up
Post #322577 14th Apr 2015 1:59pm
ah yes, thats correct...i like your idea and i might move mine up there to.. Thumbs Up ... - .- -.
Post #322579 14th Apr 2015 2:06pm
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
Very James Bond Stan, is that the ejector seat button ? Rolling with laughter Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #322582 14th Apr 2015 3:08pm
i press that and buck blue FF's blow up.... Twisted Evil Wink ... - .- -.
Post #322586 14th Apr 2015 3:35pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Shocked Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #322669 15th Apr 2015 9:03am
So what are you using them for NDFI ? (and for that matter stan too!)
I have a couple of switches (one momentary, one illuminated toggle) to power up and start my car pc, in the coin tray in front of the gear lever
Post #322733 15th Apr 2015 6:23pm
One for the additional map reading lights, one to switch on and display the reverse camera when driving ( also to allow use of this camera as rear journey camera via recorder) and one for the dilithium crystal regenerator. Thumbs Up
Post #322748 15th Apr 2015 7:56pm
Glad to to she's "giving you all she's got! Wink .
Post #322787 15th Apr 2015 10:46pm
