Home > Technical (L322) > Changing Turbo on a 3.6 TdV8
INTERCEPTOR
Switzerland 2011 Range Rover Autobiography Black TDV8 Barolo Black
Hi guys
My Range Rover showed me the 'Engine System Fault'-message last week and lost power. Sad The dealer told me to change the left hand Turbo, and quoted an incredible amount of money. And this without testing the EGR-valve and hoses...
So I wanted to ask if anyone has ever changed the Turbo himself..? I'm a mechanic myself, but I don't work on the job anymore. My first problem is how to reach the turbo, should I remove the left wheel case, or try it from above...? Evil or Very Mad
I would like to check the turbo (removed) before I order a new one.
Any recommendations would be appreciated.
Thx
Marco
Post #322598 14th Apr 2015 5:54pm
Mikey
L/H turbo...
Needs the diff removed.
To remove the diff, the subframe needs lowered.
As the steering rack is bolted to the subframe, this needs disconnected.
And the engine is bolted to the subframe, so this needs supported.
Its not a quick, or particularly easy job
Post #322606 14th Apr 2015 7:10pm
INTERCEPTOR
Thanks for the fast reply! Sounds like I'll have to take 3 days off to get the work done... Shocked
Post #322629 14th Apr 2015 8:26pm
Mikey
It took me best part of a day to remove both turbos at the side of the road
From memory, it took a day and a half to rebuild and get running again, though there were a few extra issues to contend with during the rebuild
Post #322637 14th Apr 2015 8:58pm
Quick check of the top turbo hoses if you haven't already, the right hand side one splits under the webbing at the engine end.
Worth a check for 5 mins before diving into the turbos.
http://www.fullfatrr.com/forum/topic26843.html There is nothing that can't be fixed with a hammer😜😜
Post #322658 15th Apr 2015 7:39am
As stated above... Exhaust every other avenue first sir... Then if you do need the Turbo, do them as a pair! If one is failing then the other won't be far behind! The RH Turbo is relatively easy compared to the LH side which is a little more buried... If you can get the car on a two poster and you have a reasonable level of spanner wielding ability then you should be alright sir... Thumbs Up
Post #322661 15th Apr 2015 8:27am
