![]() | Home > Maintenance & Mods (L322) > ZF 5HP24 Transmission rebuild - How To ? It begins..... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8715 ![]() ![]() ![]() |
Well got the new box fitted today, all went well, and what a difference.... silky smooth changes, pickup from rest is much, much better, the old torque convertor must have been well worn...
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Rebuild or replacement it was very interesting. You have my admiration. Well done. |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
Well done Pete, a very intresting read |
Cheers
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1014 ![]() ![]() |
Pete,
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Well done pete glad it worked out for you and car is back to normal. |
Yep, well pleased, Cheers
Well done Pete, I'm glad you are mobile again |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Hi to all, I am removing my gearbox, same model as 'haylands' ( Bmw v8 )and wonder if anyone has removed a gearbox, and has any tips on getting the four flex plate to torque converter bolts out, as the front subframe is right in the way. I know how to remove them, just what tool has anyone had success with, ie an odd shaped ring spanner, or various sockets etc. I have to be careful not the round them off, and they are definitely not playing cricket today. |
John, PM replied to..., I don't think you will round them off they are high tensile bolts, I used a 17mm 3/8 drive deep socket, they are a pain though.... Pete
andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102 ![]() ![]() ![]() |
hi , I started to remove my zf 5hp24 transmission, but I have a question about torque converter bolts.
Pretty sure they are 17mm, you need a deep 3/8 drive socket on about a 1ft ratchet, feed it in and work your hands round the sides and it is possible... they are high tensile bolts so you won't round them off, they are very tight though...
thanks so much |
