Home > Technical (L322) > Bizarre steering wheel wobble
jke11y
My 2007 tdv8 has done this twice now. Driving along at about 50 and all of a sudden there's about an inch of wobble in both directions. It does it for a few seconds then goes back to normal.
A quick Google shows the valve for the steering as a likely culprit - am I on the right lines? I've just sat on the motorway for half an hour and it's perfectly smooth then all of a sudden a wobble then gone. It last did it a couple of weeks ago.
All tyres / discs / calipers fine.
Edited to add; when it does it, the steering is "steppy" or notchy - then it goes away.
Post #322687 15th Apr 2015 11:26am
Check bushes first , drop links track rods that sort of thing before looking at the expensive answer . 2008 MY Supercharged
Post #322690 15th Apr 2015 11:33am
jke11y
I checked all those and replaced a lower arm very recently. The feeling of this is very immediate on and off and feels hydraulicy through the wheel. What level should the pas fluid be at?
Post #322691 15th Apr 2015 11:36am
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
I had random steering wheel wobble usually going 50-70. Just had my pads done and the mech said one of the calipers was struck. ,!! Not done it since Very Happy
Post #322878 16th Apr 2015 9:08pm
bag 933s
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
i seem to have this issue also around 50-70 there seems to be a vibration or lumpiness i thought maybe a wheel balance issue, but im replacing rear discs and pads this week, but pulling away and under load its perfect just at motorway cruising speeds it noticeable
Post #323446 21st Apr 2015 1:56pm
bag 933s
mine turned out to be 5mm spacers cast and not turned so all over the place on each wheel....drives lovely now, the love is back
Post #329293 24th May 2015 4:42pm
"5mm spacers cast and not turned"
where, what, how ? Is this on the brakes? .
Post #329294 24th May 2015 4:47pm
bag 933s
5mm wheel spacers...not hub cantric.... very cheap cast items.....they served no purpose what so ever, took all 4 off and she drives lovely now
Post #329299 24th May 2015 5:33pm
Zirconblue
A tired Power steering pump would probably do it, or if the belt is slipping.
Post #329307 24th May 2015 7:10pm
jke11y
Just to round this off, as another poster mentioned I had a sticking caliper. Changed it and no more issues.
Post #330289 31st May 2015 7:48pm
