![]() | Home > Maintenance & Mods (L322) > Brake System Diagnosis, Parts, Labour on RR 08 & 09 |
luv2xlr8 Member Since: 29 Mar 2015 Location: Dubai Posts: 57 ![]() ![]() ![]() |
Any support for a newbie fellas, whats the best way to diagnose the brake system current condition? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8722 ![]() ![]() ![]() |
Spongy pedal could be, worn master cylinder, air in system, old brake fluid, perished flexi pipes and probably a few other things...
Thanks Haylands. |
So im at the garage, sourced original parts from a supplier close by, had them installed, just a replacement job as requested.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
New brakes normally need a period to 'bed in' so you'll usually find they feel weak for the first few miles, then they gradually improve. |
Zicrinblue, good to know |
Think you're worrying too much, just drive it, if something breaks, fix it, if not, enjoy it..... Pete
Worrying, nah, just diagnosing the issue, forum's much needed experience plays a crucial role here |
Sorted.... |
Haylands |
2008 Vogue SC
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
A soft pedal can be due to only fitting new pads as the disc will have a small lip of rust at times only minor but enough for the new pads to ride high on that abd you can get a siight deflection / bending of the pads till they bed in and wear that lip into them.
Thanks Steve.
2009 HSE
