![]() | Home > Technical (L322) > Gear select delay - auto oddness |
My immediate thought is that the colder more viscous fluid takes slightly longer to build pressure than on a warm day?
Rangie in oz Member Since: 25 Jul 2010 Location: liverpool Posts: 52 ![]() ![]() ![]() |
please let us know if you find a fix |
Pauld Member Since: 15 Mar 2010 Location: Sheffield Posts: 199 ![]() ![]() ![]() |
Your gearbox is giving signs that it may be on the way out. The torque converter is the part that breaks in the box.
Did they use the propper fluid? ![]() |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Yes, they are specialists and we had a long interview before I let them touch the car. |
Right, called the specialist as its playing on my mind. After a quick telephone chat the thoughts are,
Bum!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35696 ![]() ![]() |
sorry for the bad news , the auto box is always a worrying thing... ... - .- -.
OK Chaps, Just though I'd keep you posted on my current cause of sleepless nights |
RE them failing at 80-100k I'm sure this has something to do with the oil life being 50-60K and the fact they never get a change.
Your specialist in Luton does an excellent first rate product, at a price.
You've had 5 gearboxes and you're reccomending them!? ![]() |
Yes, the first 4 were from Land Rover, under warranty.
You could be right Dan re the fluid changes. The reading does suggest they are much weaker in construction than their ZF counterparts. I'll be looking at fluid changes say every 20,000 or so in the future and filter every 40,000 miles.. just to be belt and braces. 2010 Disco XS TDV6, 2009 Freelander 2 GS
