Home > In Car Electronics (L322) > Knakered Radio
winslo
2005 Range Rover Vogue Td6 Adriatic Blue
Knakered Radio
Got a 2005 range rover with touch screen nav harman/kardon
The head unit won't turn on, just flashing red light on the power button. Has the land rover screen on but won't do anything
any ideas?
Also blower fans won't work I'm assuming its the hedgehog resistor gone?
Thanks
Post #323533 21st Apr 2015 10:22pm
Probably the Bluetooth module has water in it? The left side of the boot leaks and if one unit on the M-O-S-T ring stops working then your symptoms are what are usually reported sir...
Post #323536 21st Apr 2015 10:31pm
winslo
i checked the back and no water in sight?
Whats the repair cost if it is bluetooth module?
Post #323537 21st Apr 2015 10:32pm
First things first sir...You need to work out which component in the M-O-S-T ring has failed! I mentioned the BT module as its on the top of the stack and most common for water ingress failure, but you say yours is dry... Rolling Eyes
Post #323539 21st Apr 2015 10:37pm
Discotigger
I would check all the fuses first, make sure that they're not blown and that they work (i.e. test the fuses on a multimeter).
If they are all good, then test each unit on the MOST ring by looking for the light from the fibre optic cable coming from the connector when unplugged from each unit.
Always best to be methodical with the Entertainment system. Thumbs Up
Post #323627 22nd Apr 2015 12:34pm
winslo
I pulled the plugs out of the Bluetooth and it seems there is some water ingress in there, as some holes/pins are white and corroded
As the Bluetooth Is crap is there a way to bypass it?
ThANKS
Post #324120 24th Apr 2015 9:39am
from memory someone here used a cut down 'bic' pen [without the insides] to do this ... ... - .- -.
Post #324122 24th Apr 2015 9:46am
found it,
http://www.fullfatrr.com/forum/post248518.html#248518 ... - .- -.
Post #324123 24th Apr 2015 9:47am
Buy one of these... A must for the home FFRR mechanic... Thumbs Up
http://www.ebay.co.uk/itm/Fiber-MOST-optic...56731c6beb
Post #324126 24th Apr 2015 9:53am
winslo
Its fixed
Did it from a video on youtube took all of 1 minute!
Thanks for the help
Post #324301 25th Apr 2015 9:40am
