![]() | Home > Maintenance & Mods (L322) > Gearbox/Transmission in AJV8 |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 ![]() ![]() ![]() |
is the cattle grid you are experiencing at low revs when accelerating ? is making a noise or just juddering ?
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
It is a physical vibration normally only under load, ie if I pull away gently it is ok. Car had lots of history to evidence servicing and various repairs with plenty of money being spent but I couldn't find anything gearbox related. However, the garage said the level was good and the oil looked clean and a good colour. I had told them to change if felt necessary at the time but didn't want to do for the sake of and possibly cause more problems.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8616 ![]() ![]() ![]() |
I'm wondering how they know what colour the oil is if they didn't drain it out?????
Pete, oil amount equal to the volume of shudder stop added was drained off so that the shudder stop would fit in the used to top off to correct level.
Anyone recommend a gearbox specialist to take a look and change the oil
I've found most so called specialists just say.... needs a new box... mainly because they don't want to guess wrong...
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
^ second what Pete says, I had a judder at low speed and a booming sound at 50mph ish, I changed the filter and used correct grade atf as in the wiki by saintv8 ( great thread too |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Its really easy to change the filter and oil. Mine came out very clean and didn't smell of anything metallic or burnt,,,
