![]() | Home > Technical (L322) > No power to fuse 51? Engine cut out |
William97841 Member Since: 18 Jan 2015 Location: Essex Posts: 151 ![]() ![]() ![]() |
Any know where r116 relay is?? Because I think that's got something to do with it |
Any help?? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8789 ![]() ![]() ![]() |
It's at connection C1895 in the waterproof box under the bonnet... the blue relay...
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
Have you tried Fuse 15? |
Hi well I've changed that blue relay but when this happens I don't get any power to the glow plug/black connector cable...what comes through the back of the e box?? Then I pull some red cable from behind the battery and fuel filter primes and then power to fuse 51...so I'm a bit stuck...replaced the red cables into the e box still doing it...so I'm lost |
Sounds like a lose red cable behind the battery then, take the battery out and have a good look.... Pete
Yep it is a lose connection because when I cable tie the red cable to the front bolt holding the battery it's ok. But I got a feeling it's something lose below the transfer box ecu...where those 100amp fuses are...anyone had a problem with those?? |
