Home > Technical (L322) > Supercharged Coolant Problem - Temp Gauge Dropping
wealy
All you need is the ID and thickness of teh o ring - you will get one from any engineering supplies company.
Post #323923 23rd Apr 2015 11:44am
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Hunting it down now. Ideally Viton rather than Nitrile??? 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #323932 23rd Apr 2015 11:58am
ebajema
Based on a bit of internet research, I would suggest Nitrile over Viton. Nitrile has the lower heat range (up to 120 C) but better resistance to engine coolant fluids than Viton. Close finish though, Viton will probably also do fine. Buy one of both and if the Nitrile fails, switch to the Viton would be my solution Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #324094 24th Apr 2015 5:58am
RRBlue
Thank you. Such a relief to find someone to discuss o-rings with. Not many takers at home for some reason. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #324097 24th Apr 2015 6:26am
RRBlue
All done. The old o ring was completely shot: damaged from having stuck to the aluminium casting and misshapen from age and heat.
The replacement is 3.5mm cross section and 34.5mm internal diameter.
A five minute job, followed by weeks of bleeding the cooling system, but better than paying £90 for the replacement connector which you have to buy with the two hoses attached.
I hope this helps others.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated :mrgreen:  2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #324338 25th Apr 2015 2:33pm
