Home > Technical (L322) > Vision Assist Pack
IanT599
Vision Assist Pack
Currently still shopping for a car. 2010-12 4.4TDV8 with 8 speed box.
For us a must have is the vision assist pack. We like the surround camera and the blind spot monitor. Unsure if it adds anything else but we read the venture can only works with the vision assist pack too. Ideally that would be great to me to stick a camera on the tin tent as sometimes I'm on my own with it.
Anyway as some people never ordered it from new it is hard to find the ideal car.
Question is can it be retro fitted easily?
I know the cables are available online and probably the cameras too. I'd imagine it would just be a case of enabling the feature on the computer.
Please help car shopping has become a nightmare.
Post #323950 23rd Apr 2015 12:33pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Hi there are a couple of threads on retro fitting venture cam - it can be done but no small job. as for the rest of the vision assist pack you are looking at new wing mirror surrounds and front cams. Plus there is also the tow assist function of the VA pack - I suspect some electrical jiggery poker required then plus of course all the CCF configs etc.
In short venture cam yes - rest of it doubtful and in any case very expensive.
Better off getting the right car in the first place.
Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #323993 23rd Apr 2015 4:21pm
IanT599
We tow a caravan, a trailer and I'm sure the Mrs is after a horse box. Forgot about the blind spot probably also needs sensors to work properly.
Reading the manual you can setup the system for multiple trailers so for us overall the pack is with more to us than most.
At present we are waiting a call back from another dealer so fingers are crossed the numbers are ok.
It'll probably end up either A) more expensive to retro fit or B) probably won't work correctly after I fit it all.
Post #324005 23rd Apr 2015 4:40pm
ajac8
Agree - retrofitting all that lot would be lost cause on me too. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #324070 23rd Apr 2015 9:53pm
4.4's are rare with VA package... The later the car the less they stuck on um as standard! Rolling Eyes
Post #324080 23rd Apr 2015 11:06pm
ebajema
There is a cheapish hack that one of our Aussie forum members utilizes. Buy a cheap suction mount, stick a cheap older smartphone in it and us it as a Venture Cam to stream to your "normal" smartphone Smile. MY 2010 5.0 SC Galway green and sand interior!!
Post #324090 24th Apr 2015 5:45am
ebajema
Found it Smile http://www.fullfatrr.com/forum/topic24355....ne+suction MY 2010 5.0 SC Galway green and sand interior!!
Post #324091 24th Apr 2015 5:46am
heppsen
Germany 2012 Range Rover Vogue TDV8 Santorini Black
Hi, my newly wquired 2012 TDV8 has this Vision Assist with Trailer aid system.
Works a treat and its good fun using those cameras around the vehicle.
I have not actively searched for it (nor for the whole vehicle) but it was a nice
add on. The HD Logic 7 with 1200 Watts was more welcome... Thumbs Up despite slightly dissapointing me on the bass/subwoofer quality.
Back to camera system:
you can actually save profiles for a couple of trailers and the system helps you find the correct trailer type.
I do not have the venture cam though. But as I only very randomly tow a RIB I can live with this missing bit as I am able to look along the RIB on both sides with th erear view mirrors.
regards
heppsen 2017 MB V-Class
2016 Q7 (gone)
2012 FFRR TDV8
2012 Smart Pulse Turbo
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #324098 24th Apr 2015 7:02am
IanT599
Assuming the car has the VA pack from build. Would it have the charging point for the venture camera built in?
Post #324105 24th Apr 2015 8:36am
mzplcg
Correct me if I'm wrong, but was the Venture cam actually available on 2010 onwards? I'm not sure it was TBH. I thought is was only up to 2009MY.
Certainly my 2010 and 2011 Autobiographies have neither the the camera or the dock in the top glovebox.
Doing research on this I came across this link - no mention of venturecam.
http://www.roverguide.com/9707/land-rover-...age-video/
Post #324109 24th Apr 2015 8:56am
You're quite right Vision assist was never offered with a Venture cam but in the CCF of 2010> cars the companion camera file can be found leading people to think all you need is a charger and loome as well as a venture came to activate it in the CCF but I have no idea if anyone has succeeded. 2008 MY Supercharged
Post #324114 24th Apr 2015 9:10am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I have got VA on my 2010, 2011my.
The blind spot monitor is turned off when you connect a trailer.
The reversing camera cannot see the tow ball so no help when hitching up.
The sticker for the trailer assist is huge, about A4 size, so I would not want it on the front of my caravan, I can reverse a trailer anyway and if it is that difficult I would use the caravan mover.
You can have the cameras on whilst driving but it does not really help and may make you feel sick.
The profiles that you select for trailer, five iirc, I thought were for the stability system and nothing to do with the cameras but I may be wrong, do other owners without VA have the trailer profile menu?
I do not have a venture cam dock.
Ian
Post #324117 24th Apr 2015 9:25am
IanV8
Nice looking 2010 AB with vision assist on here if you don't mind white.
Ian
Post #324119 24th Apr 2015 9:39am
Venture Cam is on lots of 09/10my cars in VSE & AB guise... I think you will find it was removed as standard fit on the 11my> much like RSE i guess... Thumbs Up
Post #324121 24th Apr 2015 9:44am
IanT599
Mrs doesn't fancy a white one. It is nice looking though.
I thought that the venture was another option for the my11 onwards. I got a copy of the owners manual on topix and it listed the operation in there. I was kind of hoping that by buying a camera online it would all work from the start.
Will need to check the car we are looking at on Saturday had the charge dock.
It has almost every option we were looking for. VA pack and tow bar already fitted with other options too. I've managed to get a LR 13 pin socket so can fit that instead of the twin 7 pin one. Hopefully the ccf will be done already for the 7 pin on there.
Post #324128 24th Apr 2015 10:21am
