![]() | Home > Maintenance & Mods (L322) > Trans failsafe prog |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8719 ![]() ![]() ![]() |
Mine did that repeatedly before it started locking in 4th, then.... new gearbox...
Jimmy C Member Since: 05 Feb 2015 Location: midlands Posts: 115 ![]() ![]() ![]() |
Ok here goes... Went to Indy today and plugged in, no gearbox codes at all but lots of transfer box codes, cleared them and went down the road, stopped selected reverse BONG got the message again so straight back to garage plug in and again no gearbox codes but 2 transfer box codes which are.....
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
As you are not changing from high to low ratio, there is no logical reason why the transfer box is firing codes and faults at you, but it does.
Thanks for the reply a few things I can try, first being hi lo switch a few times then try disconnecting the lead from motor, I'm not a mech but I'm sure I can work it out, will report back after giving it a go tomorrow |
I'm still driving it is this ok?. |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1014 ![]() ![]() |
Certainly sounds like your transfer box shift motor potentiometer is playing up.
Cheers Phil , is this a part that can be changed? |
No, AFAIK, unless the guy on landrovers.net has finally come through with his re-manufacture.... .
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
I had exactly the same with my TD6.
When I unplugged my TSM. I would get the dash TFSP message at every ignition on / start but only the once and then it would go and not come back.
Yep - I can second that!! ![]() As per this video, I took my TSM off, put 12V to it and let it run for 5 minutes. It never actually worked after than in terms of shifting between low and high ratios but equally it never threw another dash fault either! Other things to consider are battery and / or alternator charging fluctuations, sometimes they can throw a fault on these very voltage sensitive cars. ![]() 2019 Renault Zoe Dynamique Nav ![]() |
Well its intermittent at the moment, so took a chance and tried changing from hi to low a few times and All works at it should
Well after a couple of months the dreaded message is back! Stil driving and changing gear nicely sometimes hi to lo works other it doesn't ignition off and on again and all is well apart from constant messages.
Well tried a lo-hi today just left with lo range flashing on the dash and selector doing nothing and stuck in lo, with a bit of messing,...eventually it did work and with the transfer motor running for about 10 seconds + it clonked back in hi range and thats where it'll be staying!! gears still change perfectly still so i guess my transfer motor is goosed? |
