![]() | Home > In Car Electronics (L322) > Loving the ACC! |
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
Rub it in why don't you |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 911 ![]() ![]() ![]() |
That's always assuming the guy in front knows the road! |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Its a fabulous system no doubt |
I agree, I love it to bits !!! The only issue is, it hardly/doesn't see motorbikes !! MY 2010 5.0 SC Galway green and sand interior!!
Not too many slow moving motorcycles over here Eygene... Most are pushing past at much higher speeds! |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
The AAC on my L405 takes you down to a full stop. It will then allow you to resume when the car ahead moves off with a tap of the accelerator. A great boon in a traffic jam (though it annoyingly leaves the brake lights on - if you engage the electronic handbrake, the AAC disconnects).
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 ![]() ![]() |
I've heard the CCF can be reset on the L322 to Jag mode allowing the same function as the L405 so you get full stop and then go again. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
When ACC first came out I had it in the Sport, it wasn't as good, was a bit twitchy and would assume a lorry to our left was in your lane and throw out the anchors.
Plenty of them in France Craig, I guess they are not used to be chased by a 500 bhp brick |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 343 ![]() ![]() ![]() |
kiter Member Since: 04 Jan 2013 Location: Inverness Posts: 182 ![]() ![]() |
Got it on the V60 and absolutely brilliant - especially now we have 120 miles of average speed cameras on the A9. Talked the old man into adding it as an extra on his A3, wasnt keen to start with but he is glad he did now. Volvo has queue assist and if you are stuck in a queue of traffic it will still work and get you back up to the set speed when the queue has cleared. |
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
Sounds ok until you get the warning on the dash like I did just the other day. Warning, radar sensor blocked. Will look into that tomorrow. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
That's the coolest error message ever.....
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
@IanT - Correct - I have enabled the Jag Cruise function with my beloved IID BT on my 2010 MY VSE as it had front radar and ACC already.
