Home > Maintenance & Mods (L322) > Diff wear
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Diff wear
When I changed the front and rear diff oil recently (at 150k), here were fine ferrous deposits on the magnetic drain plugs. On the front diff drain plug it was approx 10mm thick and slightly less on the rear diff drain plug.
I have been wondering, ever since, whether this is significant, especially as I am hearing quite a pronounced whine from the front, perhaps also a sign of wear.
Has no one any similar experience or thoughts? 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 L322 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #203337 10th Aug 2013 10:47pm
Take it off again since the change and see if there is more. If there is maybe get the diff's off and sent for a refurb Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #203343 10th Aug 2013 11:28pm
RRBlue
Thank you.
I have some spare oil, so I will do another change to see if there is more debris and investigate a service exchange unit. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #203370 11th Aug 2013 8:09am
verydisco
Great, idea, please keep us posted, ideally with pics Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #203460 11th Aug 2013 5:29pm
RRBlue
A badly worn front diff has now been diagnosed. Even after two changes, the oil remains full of fragments and the metallic whine has become more pronounced. service exchange diff £1,100 + VAT at local indie. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #252529 3rd Apr 2014 9:47pm
Sorry to hear it Sad at least changing the fluid again showed it up before it left you stranded somewhere and caused more damage. Do find out what let go though and if changing the fluid earlier could have saved it for you as could help others on here in the future Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #252552 3rd Apr 2014 11:01pm
RRBlue
After my first front diff was replaced with a genuine LR part by my local Indi, it failed with loud whining getting worse and oil leaking from the main bearing. Having waited five months for the part, it was a little disappointing. Having waited a further five months for another new diff, all well and fingers crossed that this one will last. Great support from my Independent, but question mark over Land Rover quality control. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #324340 25th Apr 2015 2:40pm
RRBlue
I am now on my fourth fromt diff.
The original was replaced at 150k with a new JLR part, as discussed earlier in the thread to solve a loud whining. This was replaced six months later with another New JLR, under warranty, diff after the new diff developed a similar whine. In both cases, I had to wait months whilst a new diff was prepared by JLR. It appears that they do not keep any stock for these type of parts for vehicles on this age; understandable really.
So when the second new diff started to whine, I decided I did not want another new JLR diff, but looked for a specialist to refurbish mine with good quality parts. This is what I have done but in the process found that the previous JLR diff comprised a mixture of non standard parts And tha failure of the main bearing had resulted in severe wear on the crown wheel and pinion.
I am now enjoying relative peace, listening to all the once familiar creaks, rattles and squeaks masked by the diff whine, hoping now that the diff saga is over.
The reason I share this is to say what I learnt. Firstly, that that a specialist is probably a better option than going for the manufacturers support at this age of vehicle. Secondly, to say that the senior technician at the LR Dealer who was kind enough to test drive my car to confirm the problem, was firmly of the view that the transmission and diff oils should be changed regularly. I have always taken the view that the sealed for life statement really means sealed for the length of the warranty and this seems to be the case. My oils were first changed at 100k, then roughly every 30k. I shall change the new diff oil after about 1k just to monitor condition and wear.
On the financial front, the latest diff rebuild cost about £1k. JLR wanted over £2.5k for another new one - £1.5k more than the previous new ones. That tells me that they wanted to price themselves out of this particular problem.
The RR has now done 210k and I have explained to her indoors that it is not just a car, it is a restoration project and will remain so indefinitely. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #411081 28th Oct 2016 10:09am
mattyp
That's some mileage on it, what else have you had to replace with those miles ?
Post #412280 5th Nov 2016 8:25pm
RRBlue
I have had it from new and replaced:
1. Front suspension links and airbags this year for the first time.
2. Rear bushes for secomd time
3. Fuel pumps once
4. Two radiators
5. One set of plugs
6. Rear upper tailgate
7. Rear wiper motor
8. All wheel bearings once
9. Rear calipers
10. Suspension air receiver
..... and hundreds of tyres and a couple of small emirates worth of petrol.
Interior foundry grey starting to bubble and black window switch rounds also worn,s o some interior work required. Rear wheel arches also need the treatment. Brake pipes also need replacing. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #412285 5th Nov 2016 9:04pm
Blimey that's pretty good, I've changed more than that and I'm two circumnavigations of the planet behind you... Thumbs Up Pete
-Click here for Thread-
Post #412327 6th Nov 2016 2:03am
mattyp
That is good going, mine feels like it's a part a week which needs changing
Post #412328 6th Nov 2016 8:05am
RRBlue
Of course there are regular service items that get spread across almost every weekend. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #412329 6th Nov 2016 8:11am
rar110
Impressive mileage. ______________________________
Post #412355 6th Nov 2016 12:22pm
Baltic Blue
I had a rear diff fail in a brand new P38, less than 1,000 miles.
The replacement was still going good when I sold the car at 100,000+ miles.
Some you win and some you loose.
Post #412371 6th Nov 2016 3:23pm
