![]() | Home > Maintenance & Mods (L322) > service item " lubricate top edge door seals " |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 ![]() ![]() ![]() |
Vaseline ? |
No no no... Vaseline is for your boyfriend, you need GUMMI PFLEGE |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8081 ![]() ![]() ![]() |
I use this |
I guess the seals dry out and leak , which is what they are doing now.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Vaseline isn't the best stuff to put on rubber seals.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1671 ![]() ![]() ![]() |
Gummi also improves the appearance as well as protects. |
thanks for the GUMMI tip , not too bothered about the appearance but its a service item that I want to keep up and my door seals will benefit from being a bit quieter. There is a winzer wurth right near me so I can pick some up |
I suppose its all about personal preferences. Personally I like mine to look its best. Cant see the point otherwise. 405 AB exec seats Baltic and Cirrus 93 RR Classic efi Remember it's easier to get forgiveness than permission! Gone in order: 4.4 TDV8 SE - gone to a good home 93 Classic hard dash Plymouth Blue 03 L322 Oslo Blue 2000 Disco TD5 ES Epsom Green 98 P38 Rioja Red 89 Classic Cairngorm Brown |
