![]() | Home > Technical (L322) > Air Suspension Heght Issue |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
You may have a sensor giving bad readings, or it may be broken (the arm), if you have the IID tool you should be able to access the readings (I don't have one so I'm not sure, but they seam to do every thing else!). If you don't then it's a stealer / indy |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8789 ![]() ![]() ![]() |
If the sensors look OK it probably wants calibrating, can be done with the IID tool or similar... not a massive job.. Pete
Pete, buddy, how is the Poseidon Rocket Lift going? or to put it another way have you done your twin turbo EAS?
Funnily enough I tried it out a couple of days ago, ran both compressors through a T junction, bodged the wiring to supply both and tested from access (lower than standard) to off road (higher then standard) I tested both first on their own and they were within a second of each other so they are both fine.. It took 1.49s with one pump and 1.17s with both so a bit quicker but not half the time... I suppose because the initial raise is from the tank and the pressure won't be any higher, then as the pumps take over it reduces the time....
Thanks for that info Pete, keep up the tinkering |
