Home > In Car Electronics (L322) > Quick bluetooth fix
thatgirl101
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
Quick bluetooth fix
Hi all,
Just thought I'd share this for those looking for a quick Bluetooth fix for their FFRR.
http://www.amazon.co.uk/Ion-Bluetooth-Cass...B00I3YLHAC
You pop the cassette in the cassette player, and it allows you to stream music via BT and make handsfree calls.
Works a treat for me.
Post #324538 26th Apr 2015 5:15pm
Richard
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
Looks good.
How long does the battery last? Does your phone pair automatically or do you have to pair it each time?
Post #324553 26th Apr 2015 6:32pm
Great find, got to be worth a punt Thumbs Up
Worth figuring out power and microphone for permanent installation Whistle .
Post #324590 26th Apr 2015 10:16pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Do any FFs have a cassette player?
If I did would be interested as nobody seems able to assist with teh factory system. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #324610 27th Apr 2015 9:23am
thatgirl101
I've used it a few times and the battery has lasted ok so far - it comes with a USB charger but not had to use it yet.
It pairs automatically as soon as the car is turned on.
Post #324612 27th Apr 2015 9:28am
mjdronfield
The early ones have an 8 track behind the screen. Hang on..... No..... It's a cassette deck.
Dare not put any tape in mine as I imagine the rubbers are all perished and I don't want any hifi issues..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #324641 27th Apr 2015 5:39pm
jaybear
France
Great find .
Ordered one . will report when received . Jaybear
2002 V8 , premier edition , 19" alloys ,
Post #324749 28th Apr 2015 10:17am
Got mine, sound quality very good for what it is. Thumbs Up
Says on the cassette for best results to insert cassette with power switch in the off position. My phone wouldn't connect, had to have it switched on.
Only problem, the microphone lead is not long enough. No worries, take it apart, undo all screws, hold it together, turn it over to the side that says this side up, then carefully remove top half of cassette (do this otherwise all the cogs come away and you won't know where they go! ) The mic lead is in an "anti-pull" loop. release it and you get another couple of inches. Cut a small slit using a craft knife near the exit point and feed the mic lead through this instead. (Remember not to tug on it now!) reassemble and now the mic lead happily hangs over the front of the screen.
Next job to see how to connect a charger lead when the cassette is in-situ, either by moving the female further into the cassette if there is room, or doing some bodger damage to the cassette hole in the car (have to disconnect battery to stop the screen going back every 15 seconds!)
Anyway, a good alternative bluetooth fix for older FFRRs, many thanks to thatgirl101 Thumbs Up .
Post #331317 6th Jun 2015 6:54pm
crispy2
Australia 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Easy fix for those without cassette player, remove factory head unit and fit an 80s cassette player in there!
Problem solved!
Laughing
might need to go and buy another navigator as well. Ha ha. '07 4.2 S/C
'13 X3M
Post #331341 6th Jun 2015 10:05pm
Owners of later models will be nicking 'em out of of the old 'uns, just to get a bluetooth connection that works ! Rolling with laughter Rolling with laughter Twisted Evil .
Post #331352 7th Jun 2015 12:17am
