![]() | Home > Maintenance & Mods (L322) > Headlight bulbs |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Brought these bulbs are they the best around at the min?
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35755 ![]() ![]() |
look good, hope they perform.. |
Not sure what height there at as inside was loose before , will a mot beam setter give me the best height to get them you think? _____________________________________________________
not sure on that because of the FF levelling thingy...i 'upped' mine in small bits with a test run after each adjustment to get the best spread of light. ... - .- -.
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
What Stan said... big improvement |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
I can safely say I will not be purchasing them! |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
being as from the factory the bi-xenons are excellent, i'm not sure why you would even need to upgrade the bulbs. |
It had odd bulbs in when I got it and a bit of a yellow beam _____________________________________________________
your from Yorkshire what can we expect ![]() ![]() Zambezi silver Vogue Se unique ![]() |
Can that be done on the adaptive ones (2011) with high beam assist Stan? The new chariot does seem a bit on the low side.... High Beam assist ![]() |
mine are adaptive so no problem there Dom...high beam assist dips the headlight when it senses oncoming headlights so pretty certain that will be ok. ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
High beam assist has NO extra function within the headlamp sir... Electronic gadgetry just takes over the function of your left hand |
