Home > Camping, Caravanning and Holidays > Tin Tent imminent |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 |
It's got the white fag packet size thing so I presume the relay is there too. The wiring harness has Westfalia on it rather than Land Rover but I guess that's because it's aftermarket and not LR supplied. The fitter tells me that Westfalia supply LR. As far as configuring it, I don't know what system they are using but they specialise in Land Rover so I suppose it will be capable. What they are saying is that the option to enable the towing pack isn't present on the car. |
27th Apr 2015 7:42pm |
Took the car back Wednesday morning. The fitter tested it and claims it is all ok. He reckons that the testers used for MOT purposes are not at the that good as they use LED's which the full fat doesn't like. I just hope he is correct and that it all works when I go collect the van next Saturday. |
2nd May 2015 2:20am |
If he has an LED board or tester then that may do it, same principle as the new 10> rear light clusters which need ballast resistors or flash all over the shop.
2nd May 2015 9:19am |
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 |
Common problem on a lot of cars is mot testers using led boards.
2nd May 2015 11:13am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Hi the Westfalia electrics kit in the 13 pin form should handle leds without any warnings. I have the 13pin loom on my 2003 ffrr and it does everthing it says on the tin!
2nd May 2015 11:44am |
This is the kit that I used
2nd May 2015 11:52am |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
We have a 2006 FF (4.4 AJV8), and I fitted the 13 pin electrics last year using the land rover supplied loom (tow-bar was a second hand Westfalia).
2nd May 2015 2:22pm |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 |
Used the same kit as miggit, no issues.
2nd May 2015 7:45pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7914 |
Paul, the suspension will level itself even if it is locked to standard height, no need to wait mate....
2nd May 2015 8:18pm |
Fair enough Pete, I haven't really tried it since I changed the EAS pump, the old one was worse than shagged, it took over 4 minutes to raise the car from low to off road And that was on a good day, sometimes it just never got there Yesterday I couldn't spell Engineer... Today I are one!
2nd May 2015 10:50pm |
It's all sounding good as to what the Westfalia loom should do, and if it all works then I will be glad I spent the extra. But with the conflicting opinions regarding LED testers, trailer boards and one LR specialist saying there is a fault while the tow bar fitter says everything is working, I will only know for sure when I plug the caravan in. Fingers crossed..........😩 |
3rd May 2015 12:37am |
I found the loom and box of tricks to be very good value indeed, yes it was more than the £50 kits that you can get, but, it didn't need the CCF to be programmed. And when you take in to account the cost of a trip to the stealers, it was a bargain
3rd May 2015 12:53am |
So........picked the van up Saturday. Plugged the electrics in and everything seemed to work as far as the road lights are concerned. The fog cut out does not seem to be working, the trailer symbol is permanently showing and the EAS is not showing as locked (although I haven't tried to raise or lower it). Other than that everything is good and we can't wait for the end of the month for a shakedown weekend away. 😊 |
12th May 2015 10:56pm |
The 06 model year has the green trailer light on all the time when a trailer is connected. What you see is correct.
13th May 2015 8:14am |
