![]() | Home > Technical (L322) > IID Tool BT and disco 3 |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1668 ![]() ![]() ![]() |
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 ![]() ![]() |
IIRC the firmware for the IIDTool is different for the FFRR and the Disco. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34972 ![]() ![]() |
battery disconnection Ash? worth a try..
Hi Chex - The IID BT is compatible with multiple vehicles so should be ok.
did you not have the engine running? ... - .- -.
no - can't when updating the CCF. It wants to turn the ignition off and on and ask that the engine is off and ignition is in the on position.
must be different for the disco cos you can [and its best to] have the engine running when you play with the ccf on the FF.... ... - .- -.
Thanks Zirconblue...
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 ![]() ![]() |
Drop GAP an email or PM, they will help you. |
WOW - Thanks Patrick for all your assistance tonight. Went through various things and resets etc... all guided by Patrick and now my mates D3 is all up and running. All updates made (DLRs, clock on display, 3 flash etc) and his radio is back again.
glad its sorted for you Ash and kudos to the GAP chaps.. ... - .- -.
cheers Stan -
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1703 ![]() ![]() |
Patrick and the guys at GAP even went as far as adding in a few options into the CCF options, to rectify issues caused by another diagnostic tool. And they were only too happy to help.
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 ![]() ![]() ![]() |
Always a pleasure |
