Home > Maintenance & Mods (L322) > Door fault
trickymickey
United Kingdom 2002 Range Rover HSE 4.4 V8 Adriatic Blue
Door fault
Hi , believe it or not , had no problems for a long while, but my lucks run out !. Drivers door central lockings packed up, looks like a door card removal job. Anyone got a price on the solenoid ? Big Cry
Post #324695 27th Apr 2015 8:43pm
It's all in one unit with the lock, I picked up a second hand one of "ia dora" (good seller of FF bits) on eBay for £34 delivered, doesn't take long to fit and works great now.... Pete
-Click here for Thread-
Post #324718 27th Apr 2015 9:19pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
something like This ..? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #325028 29th Apr 2015 8:32pm
trickymickey
Thanks for that , ordered one from Furness £34.00 .
Post #325045 29th Apr 2015 10:48pm
Have a read of this thread then if i were you, i would not lock my car again until replaced! Bow down
http://www.fullfatrr.com/forum/topic31582.html
Post #325086 30th Apr 2015 8:33am
trickymickey
Well after disconnecting battery (wary of airbag ) and waiting awhile , stripped doorcard off and proceeded to pull old latch out . A bit of messing about ! finally got old latch out and built new one up with cable for door pull and top button, took grommet out to pull key lock on outside. Second hand latch was loosely screwed to door , then i re eentered the key part on the outside of the door into the latch, and tightened the retainer for that bit up. Finally tightened latch and reconnected battery. Lock mechanism worked up and down off fob , but shuddered a bit , thought this might be because the door was open....so shut the door .Locked the door and it wouldnt open again .... Panic , so i disconnected battery again . After a quick cuppa the battery was reconnected and normal service resumed .....Phew !. Fuse 24 apparently will do the same trick, hopefully this will now prove to be reliable !
Post #325393 1st May 2015 5:04pm
Sorted now, that's the main thing... Pete
Post #325417 1st May 2015 6:37pm
