Home > Maintenance & Mods (L322) > MOT Advisory?
Andy B
MOT Advisory?
Just had the FF MOT'ed at a local Kwik-Fit (probably a mistake, but they were cheap Laughing ). A useful advisory, front brake pads worn...fair enough, I'll get them changed. But two further advisories :-
1. Under-trays fitted obscuring some underside components
2. Engine covers fitted obscuring some components in the engine bay
Really....no Censored Sherlock, suspect the tester needs to get out more Rolling Eyes SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #324654 27th Apr 2015 7:10pm
Laughing Laughing Laughing ====================================
Post #324657 27th Apr 2015 7:25pm
Andy B
Unbelievable Mick, next time I will remember to remove the plastic engine cover and the under tray! What a Censored ! Laughing SDV8 AB MY 2019
Post #324658 27th Apr 2015 7:32pm
i suspect it is just to cover themselves, should a brake line fail under the plastic then they can say they couldn't inspect it! Rolling Eyes Rolling Eyes
never had those on mine though. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #324660 27th Apr 2015 7:38pm
Andy B
Thanks NMJ, never had that on the 2006 S/C either. As most modern cars have plastic engine covers these days I can't understand how this can be an advisory....maybe time to do a Victor Meldrew and complain to the Driver and Vehicle Standards Agency (DVSA). If I can be bothered...... SDV8 AB MY 2019
Post #324668 27th Apr 2015 7:50pm
gg2201
To be fair it's not just Kwik Fit, we've had it on the merc and the RR where we go (Not Kwik Fit) Laughing 2011 4.4 TDV8 Autobiography
Post #324671 27th Apr 2015 8:08pm
There not allowed to remove any covers for the MOT so a lot of places do it to cover themselves....
Maybe next time you have something a bit dodgy you could just cover it up with a bit of plastic and get a pass....!!!!! Pete
-Click here for Thread-
Post #324683 27th Apr 2015 9:07pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
FYI it appears they won't even remove a child seat in the back of my wife car to check the seat belt...! She got an advisory on her last MOT because of that. (and it is ISOFix so would only take 10 seconds to remove)
New rules I guess.... Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #324688 27th Apr 2015 9:27pm
Andy B
Thanks chaps, good to know it wasn't me being singled out! Thumbs Up Thumbs Up SDV8 AB MY 2019
Post #324741 28th Apr 2015 8:22am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
I had exactlty the same advisories. The MOT tester (independent) told me that under "new" MOT rules they should give these advisories to cover themselves. So for example, if an accident occured due to a corroded brake pipe but that brake pipe is hidden by under trays then there is no come back on them. On the basis that "trays" vary extensively by model it is not considered reasonable, nor does time allow, to remove them.
Much of the MOT is so out dated today, if a vehicle turns up with a broken windscreen it will fail the MOT. If a vehicle arrives with no windscreen at all, it would pass. Madness! Shocked
See posts here: http://www.fullfatrr.com/forum/topic30611.html
Like you, I was really narked to get the advisories but I see their point I suppose. Rolling Eyes 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #324744 28th Apr 2015 9:07am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
And also new is the tmps on new cars ( all not just FF's), if they have been disabled they will fail the mot! I was told this last night by Mrs WD who works at a garage, A customer was having issues with the tmps on their Ford euro box, they mentioned to disable it so not getting the warning on the dash but the MOT guy who was lissening said you cant, anything from November 14 on !
How barmy is that!!! Thud If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #324746 28th Apr 2015 9:19am
Andy B
Cheers Skot, next year (assuming I haven't gone L405 or AMG C63) I will get the MOT done at a Main Stealer and see if they are any different Thumbs Up SDV8 AB MY 2019
Post #324747 28th Apr 2015 9:21am
SKOT
It's all got very complicated. The MOT guy showed me the manual of things they need to take in to account and to be fair, they have a lot of hoops to jump through now.
Anyone who's (lucky enough Laughing ) to have had a P38 will remember that the ABS light stayed on after engine start up and then went out when you went above 3-4 MPH, some self test feature. But this is all stuff they need to know about, multiply it across all makes and models and there is a lot to take into account.
One thing is for sure, the days of taping over or taking out the engine managment, ABS lights are gone. These guys check that all the lights come on with the ignition and that they all go out when the engine is started. 2006 4.2 SC
Post #324748 28th Apr 2015 9:38am
Zirconblue
The basic rule is the tester is not allowed to dismantle anything, they can only test by what they can touch, feel and hear.
Noting that covers are fitted is just a backside covering move by the tester. ie. if the tester passes your car and then a mile down the road you're stopped by Vosa and they discover you don't have a cat fitted for example and say the car shouldn't have passed an MOT. The tester is covered because he/she has noted covers were fitted and they were unable to see that a de-cat pipe had been fitted.
Theoretically you can have virtually worn out brakes, so long as they pass the brake test. Depending on your wheel design and the type of splash shields fitted to discs, it might not be possible to tell how worn the discs are without removing the wheel.
Post #324763 28th Apr 2015 10:57am
RiccartonRR
My local indie has just dropped the wife's Cooper S off after testing it this morning and I've been teasing him about an advisory he's noted -- "001 3mm remaining on o/s front tyre" Rolling Eyes
I said you lot were onto him Laughing Laughing and even he admitted that with the current annual mileage (2500) that tyre has years left in it!!
He did say though that with the way the MOT regime is set up they feel as though they'll have their collar felt if they don't list something!!!
Post #324773 28th Apr 2015 12:01pm
