![]() | Home > In Car Electronics (L322) > If a LED turn signal flashes like this is it broken? (video) |
Turn the engine off and put the hazard lights on... Does it do the same then? |
broly Member Since: 10 Mar 2015 Location: Australia Posts: 41 ![]() ![]() |
Sorry about Taking so long to reply. Stupid work. I've just checked. ignition off. Key out. Hazards on. No change.
OK next thing i would check would be to unplug the light and run a + & - from a clean source and see if the light behaves then... If not, i would suspect the light is faulty sir... |
nah, no change again. faulty light it must be?
Change the 3 ECU's over first as one controls the Ind from memory! |
phat_dogg Member Since: 28 Mar 2017 Location: Sydney Posts: 8 ![]() ![]() ![]() |
I know it's a little late, but did you end up getting this fixed or did you come to the conclusion that the whole headlight is faulty. |
