![]() | Home > General > MY11-12 |
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 ![]() ![]() ![]() |
http://newsroom.jaguarlandrover.com/en-in/...ss_010411/
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 ![]() ![]() |
Both great links but still unsure of the exact difference between the AB and VSE.
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
I'm sure someone will come along and tell me I'm wrong but I thought all AB's had to be judged on their own merit as it is possible for one to have a lower spec' than the VSE - it just depended on the customers requirements at the time. |
iKushtyy Member Since: 19 Apr 2015 Location: London Posts: 94 ![]() ![]() ![]() |
Order of trim is HSE, Vogue, Vogue SE. Don't think I've missed any out.
That only applies to pre 2010 cars. With the last facelift in 2010 came Autobiography as an off the shelf spec , it was more about interior trim quality than toys as most toy were available across the range , there are people more familiar with the specifics here but mainly it was things like leather headlining and even more wood and unique wood choices as well as exterior brightwork . Stuff like that . 2008 MY Supercharged
and to add to the trouble, outside the UK you did not get a Vogue SE as the Vogue was the full option thing anyway - followed by the AB.
Last time I looked Staffordshire was a little short on Cuckoo clocks and Alps |
Got plenty of Cuckoos just not the ones which sit in clocks. |
OK, AB from 2011 onwards was the same base spec as a Vogue SE. it got the same toys, bells, whistles, call them what you will EXCEPT the extended leather kit which AB had as standard.
Another thing that doesn't help are the dealer adverts not being typed up correctly and options not listed or worse. Options added then you turn up and find it doesn't have it. |
Welcome to the world of used car dealers in general sir... Believable bunch... Honest as the day is long... |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1424 ![]() ![]() ![]() |
The Spec comparison guide for the 2011 Range Rover says that AB is VSE plus:
Yup - guess I was wrong then ![]() ![]() ![]() It's just like being at home ![]() |
From memory, all the above were also standard on VSE. Wheels were different depending on engine, (Petrol or Diesel) but the rest were on VSE as standard. |
