Home > Maintenance & Mods (L322) > New car, what do I need to do?
chex
Kenya
I've just bought an 04 L322. Is there anything I really need to check or change?
So far I've decided to:
- Change gearbox oil and filter
- Change engine oil
- Check and/or change diff oils
- Flush radiator (people here have a tendency to use tap water)
- Change PCV hoses
- Change belts
- Check timing chain has been done
What else should I look out for?
Post #324938 29th Apr 2015 1:21pm
ebajema
You are very right about using tapwater. My 06 4.2 blew both heat exchangers due to the bloody tapwater they put in. I was not amused to say the least Sad
List looks good, would add brake fluid as well (very hygroscopic stuff).
Air filter of course.
You may also want to change the fuel filter.
Is it a petrol or diesel ?? MY 2010 5.0 SC Galway green and sand interior!!
Post #324940 29th Apr 2015 1:31pm
chex
Kenya
It's a 4.4 petrol. I'll change fuel/oil/pollen filters.
It's having new rear discs put in so I assume that also means new fluid? I hope so anyway.
I just noticed you're in Nusajaya! I've been looking into moving there!
Post #324942 29th Apr 2015 1:33pm
buy an iidtool, it will become invaluable where you are.. ... - .- -.
Post #324943 29th Apr 2015 1:34pm
chex
Kenya
Thanks, that's on the list too.
Post #325008 29th Apr 2015 7:40pm
johnboyairey
buy a forum sticker!
cheapest £3 mod on your rangie
Post #325009 29th Apr 2015 7:47pm
You don't do anything to the hydraulic side of the brakes when changing discs, ask them to change the fluid whilst they are doing the discs, will be cheaper than doing it on its own...
Don't worry about the timing chain unless it's noisy.
Add transfer box to your oil check/change list..
Only use genuine oil in everything, do not accept "same specification" oil as it just won't be....
Then stick a big grin on your face and enjoy.... Pete
-Click here for Thread-
Post #325014 29th Apr 2015 8:20pm
viper
owners workshop manual says use freshwater in the coolant. however if I lived in a very limescale area in the south I think is use rainwater , filtered . Up here our water is very soft with very low mineral contact
Post #325036 29th Apr 2015 10:07pm
chex
Kenya
Changed coolant last night. Radiator and coolant reservoir are new, which is nice.
After a year of owning a Subaru I had forgotten I even owned tools. Three days after buying this all tools are back out; I call my spares guy and he mentions that he hasn't heard from me in a year, which is when I sold my last RR. Sigh.
At least working on the L322 you don't walk away with bloodied knuckles and fingers unlike the classic.
Post #325497 2nd May 2015 9:07am
chex
Kenya
VANOS noise is gone with oil change \o/
Changing PCV hoses tomorrow. Still had original BMW clamps so I assume they've never been changed.
Post #325970 4th May 2015 4:57pm
chex
Kenya
Last night after being on the road for about 15 hours with no problems it started bogging down and losing power. I pulled over and gave it a few minutes and it was fine.
Will change fuel filter and spark plugs in the next few days.
Any other ideas what could be wrong with it?
It also had its first taste of mud. Amazed I didn't get stuck considering I don't have good tires yet.
Post #326776 8th May 2015 8:26pm
Bstrong
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Found your post re: power loss when searching for the same issue. You find out why it does it?
Post #327141 11th May 2015 11:15am
chex
Kenya
It hasn't done it again but I assume it has something to do with a vacuum leak.
Could also be dirty fuel filter, dirty injectors, 02 sensors. I haven't had my codes read yet.
http://www.rangerovers.net/forum/6-range-r...4-4-a.html
http://www.rangerovers.net/forum/6-range-r...gging.html
Post #327142 11th May 2015 11:18am
