![]() | Home > Technical (L322) > P0314-01 Fault Code and Live Test Values |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1881
Cylinder 2 is massively over fuelling, causing your misfire |
| Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804
Cheers for that info, much appreciated. |
Anything over +2 is bad...
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Take two injectors out and swap them around... If the fault moves you know its an injector... If it stays its either wiring or mechanical (probably wiring loom related though! |
Many thanks for the replies and suggestions guys. |
| jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299
Hi what was the outcome as I have the same issue and fault codes at the minute.
