![]() | Home > Maintenance & Mods (L322) > Air Conditioning not cold |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8714 ![]() ![]() ![]() |
They only sell something you can put in, not take out and lets face it there are loads of things you can buy that you shouldn't use because of some regulation of other, see how many items, even in Halfords" say "NOT FOR STREET USE"
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
Thanks Guys.
I must say, had the air con system leak tested, cleaned and a re-gas by a Land Rover independent and it's icy cold now. The levels were very low, which is odd as my Mazda (10 years old) has never been re-gased and is still icy cold as the day I bought it. I am hoping I won't need to have this done again for a few years at least. |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I've used one of those halfords kits on an old Fiat i had, it worked a treat.
John Member Since: 18 Feb 2014 Location: Longfield Posts: 69 ![]() ![]() ![]() |
ive had problems with mine
I checked my last summer when the outside air was 23C.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
the WM mentions 3 to 4 degrees centigrade ... ... - .- -.
thats great guys
still on the quest for proper air con
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
With mine on the auto setting, if it's hot, the fan comes on at a high speed and then drops back as the temperature inside stabilises. So I agree with your premise. John
If the gas pressure is low it wont go full blast, it takes a little time for the compressor to bring the system pressure up, so normally there is a brief pause while it does this before it comes on full blast.
ok i will try cleaning that out
Plus one on the temperature sensor. There is a post or two about how to clean them on the forum and probably in the Wiki as well |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3239 ![]() ![]() ![]() |
Edit. Sorry this was for the OP, didn't get all the way to the end of the post!
