Home > Maintenance & Mods (L322) > Rocksliders, well you can't buy them, so...
I actually bought the metal to make these about a year ago but haven�t been fit enough to crawl about under the FF, still waiting for the other new hip and then a knee!! Anyway that�s my excuse�
We are off to North Wales this weekend and it is one of the most severe trips we do, you usually get some form of body damage so that�s next weeks job sorted!!! Anyway I thought I�d better get on with them�
I took the sill covers off last year and worked out that 80mm X 40mm X 4mm box section would be a good size for them, the sill is flat from front to back, the mounts for the factory jacking points hang down about 6mm, I wanted support along as much of the sill as possible so decided to fill in between the jacking points with some 6mm X 50mm plate.
Also found surface rust underneath the jacking points and along the seam of the sill
The plan was to weld the 6mm plate to the sills with captive bolts to hold the sliders on, then two supports into the original inboard mounts for the factory running boards.
First job, mark up the box section with the placement of the jacking points then cut the 6mm bar between and pop rivet it to the box section to hold it in place for drilling all the holes.
Then mark up 5 fixing points and three alignment holes and pilot drill all of them.
Offer it up to the car, held up with a trolley jack and clamped to the sill tight up against the protruding sill seam, then drill through all the holes into the sill.
Remove the box section and open out the top fixing holes to 12mm to accept the M10 A2 stainless bolts (I used stainless nuts and bolts throughout) Drill clearance holes in the sill for the bolt heads.
Then open up the bottom holes to 30mm to be able to get a socket on the nuts inside the box, this box section is strong enough to bolt right through without collapsing, but you then have nuts hanging down that get damaged when the sliders come into play.
I then realised that in my current condition there was no way I was going to be able to weld the plate to the sill so called a mate who said he�d do it for me�
I was just going to get him to weld the plate but he had some tree slider bars already bent up from a cancelled order (he makes bumpers etc for Defenders and Disco�s) They were just the right length. I didn't want them too long to cause problems with trees and logs getting stuck between the bars and the front wheel�.
We riveted the plate to the sills with the alignment holes drilled earlier and he soon had the whole lot welded up and bolted on and he tacked on the two supports, I got home and took them off, finished the welding (on a bench) and cleaned them up.
I wanted them galvanised so had to drill drainage holes in the box and the bars to let the zinc get in and out�
Whilst they were being done I managed (just) to clean up the rust on the sills with a wire cup on an angle grinder, I also did the rear arches as they were getting a bit scabby, treated all the rust, seam sealed the plate and stone chipped the lot, including the rear arches as they get a lot of abuse off road, I top coated the arches to match the FF..
There are ten holes down the sill covered with grommets, seemed like a good idea to take them out and inject the box sections with some cavity wax till it ran out of the drain holes
Picked them up this morning looking very bling!!
Soon had them bolted back on and the large holes sealed with grommets (see how long they last before they get knocked out??)
Cut down the plastic sill covers to fit back on and job done�..
They don�t stick out too far�.
They do look rather bling at the moment, it will get darker as it ages and I haven�t decided if I�ll keep them like this or paint them, they�ll do for now� kinda match the wheels!!! Pete
Post #326150 5th May 2015 7:13pm
Andy B
Great write up & pictures Pete and the rock sliders look the biz. Hope you have great fun in Wales and your Fullfat looks fantastic. Thumbs Up Thumbs Up SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #326152 5th May 2015 7:21pm
They look far better than any set of sidesteps and have the added benefit of providing increased side protection.
Painted black, you'd hardly notice them.
Excellent job!! Thumbs Up Si. <This is my name.
Post #326162 5th May 2015 7:55pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Very nice they look too Thumbs Up
Which part of North Wales you going Pete? I used to know some great lanes when I was into green lanning many years ago. Whistle If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #326164 5th May 2015 8:05pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Looking good mate...enjoy Wales. Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #326165 5th May 2015 8:12pm
miggit
Nice job Bud Thumbs Up
Think I'd leave them in the natural finish, cos paint don't like to stick to galvi, and you be forever repainting them, bit like the Forth Rail Bridge, only a bit smaller and better engineered Very Happy Yesterday I couldn't spell Engineer... Today I are one!
Post #326171 5th May 2015 8:42pm
Thanks chaps,
Welshdragon, On Saturday, starting near Llangolen through Glyndyfrdwy past Corwen, Llandrillo down to Llanarmon Dyffryn Ceiriog then back..
Sunday, Start at Corwen, through the carwash towards Cerrigydrudion along to Ysbyty Ifan then a big curcuit around Betws-y-coed and back....
Paul M, cheers, enjoy yur wedding anniversary....
Other Paul, you can paint it fine if you do it properly with the correct stuff.... Pete
Post #326177 5th May 2015 9:06pm
miggit
Ah, but, it will still come off at the first stump or rock that you find, and then you'll be back to the silver! Give it a couple of outings under water and they will soon dull down to a nice silver grey, that shouldn't take you long to achieve Laughing
And yes you can paint galvi, but it does require a special etch primer, which aint cheap, and will only be a strong as normal paint, bearing in mind that even chassis paint and stone chip wont last off road, I would personally learn to love the Zinc plate Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #326191 5th May 2015 9:52pm
viper
what do you do for a living, you are very talented and knowlegable about RR ?
Post #326192 5th May 2015 9:59pm
I had the full Zinc effect on my old Paj... soon dulls, just not too sure about it on the FF though.....
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #326193 5th May 2015 10:01pm
Welshdragon
Pete some good lanes there pall, Llangollen one is a good one Thumbs Up I will dig some grid refs out tomorrow for you, you might be able to do on route. If the one im thinking of at Ysbyty Ifan ( V gully lane) the gate/ stone wall is very very tight, I think I have a picture on a 90 going through, will check pictures tomorrow also. If it dont work.......burn it!
Post #326196 5th May 2015 10:18pm
Yeah, it's the V gulley, not as bad these days as it was years ago, and not as tight....
Viper, I haven't got time for work.... I own a Range Rover Laughing Pete
Post #326198 5th May 2015 10:23pm
Thanks for the offer of the grids.... we try to change the route every time we go, routes sorted for this weekend but I'm pretty sure we've done about every lane that's open over the years.... Pete
Post #326199 5th May 2015 10:25pm
Welshdragon
Shocked A 322 can get through the gate way now...... what you do breath in Laughing If it dont work.......burn it!
Post #326201 5th May 2015 10:30pm
I'll let you know Monday... Thumbs Up Pete
Post #326204 5th May 2015 10:50pm
