Home > Maintenance & Mods (L322) > torque convertor oil on a gearbox flush
viper
was speaking to a guy who runs a auto gearbox repair garage today and was asking him about flushing machines. he said a gearbox flush over a simple drain and fill is pointless as the oil in the torque convertor still does not come out and that is usually 50% of the oil
anyone care to comment ? surely that cant be right
Post #326175 5th May 2015 8:59pm
The oil in the TC gets pumped round like the rest of it... it doesn't just take root there..... Pete
Post #326178 5th May 2015 9:10pm
viper
thanks for your reply , he was positive that 40% of the oil will stay trapped in the TC due to the small holes in the TC. He was rebuilding one while I was there, he said the flush would push oil through the transmission but so much is trapped in the TC the flush just passes over the holes and inlets , it made sense to me anyway.
he said the only way is to seperate the tc from the box or just perform several flushes with 100 miles inbetween, ive googled this and im seeing the same story on some other sites.
do you work on gearboxes, do you know this for sure?
Post #326181 5th May 2015 9:22pm
You said in your first post that it doesn't come out.... well that's not true it will come out... he maybe correct on how long it takes, he may not be, I've never taken a FF one apart, god knows why they don't put a drain on it... be simple then...
You will still get more oil changed with a proper flush than just dropping the oil a few times though.... Pete
Post #326184 5th May 2015 9:28pm
viper
thanks haylands, I guess he was half right and trying to justify why they don't have a flushing machine. as you said more comes out with a flush so maybe that's some from the TC, in truth I bet some stays in the TC
when I have my flush im going to catch the old oil and as it turns good I will swap containers, the amount of old oil v total capacity is whats trapped
Post #326188 5th May 2015 9:39pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
No sure its the same for a ZF box as my GM 5L40E. But I have just rebuilt my auto. First I drained the oil out. Got about 6 litres . Them I just let it sit for a few days with the drain plug out. Eventually got most of the oil out. Took awhile but then I had lots of time.
Post #326234 6th May 2015 3:01am
