Home > Wheels & Tyres > Speedo difference between 20" and 19" wheels?
Roystonh
Hi all
I am thinking of going down to a 19" wheel from a 20" for a more comfortable ride. I know that its possible to get the speedo changed by the dealer, but does anyone know what the difference in the speedo reading would be if I left it unaltered until I can get booked in?
Cheers Roy 2005 L322 Vogue Gold gone
2006 L322 Vogue Black gone
2011 L322 Vogue Silver gone
2011 L322 Autobiography Black gone
2015 L405 Autobiography LWB Black gone
2019 L405 P400e Range Rover Autobiography LWB Eiger grey / black roof gone
2001 P38a 30th Anniversary Wimbledon Green gone
2019 L405 P525 Autobiography LWB British Racing Green
Post #322534 14th Apr 2015 10:00am
It's the tyres that matter
There are loads of online convertors that will give you the % difference
If you fit the standard tyres that LR fit to 19" wheels, then they should be very close and no further adjustment needed
255/55/19 are the same diameter as 255/50/20
Post #322541 14th Apr 2015 10:38am
Roystonh
They are official LR, so that should be OK then, cheers! 2005 L322 Vogue Gold gone
Post #322543 14th Apr 2015 11:04am
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
If you run stock size tyres on 19" & 20" they will be the same .
255/55-19 are the same as 255/50-20 & 255/60-18
Post #326237 6th May 2015 6:01am
miggit
The 19's are 0.004" bigger than the 20's, and I'm not even going to bother trying to work out how much faster you'll go on an extra 4 thou, it will be a fraction of a mile an hour when your flat out. The speedo's read slightly over, so there is no way you'll set a camera off, providing you stick to the speed limit Wink
My car is doing 69 mph when it reads 70 mph on the speedo, if your that worried about it, find someone with an after market sat nav that shows the speed your traveling at and check it against the speedo. If you cant find someone with a sat nav then I'd suggest that you consider buying one, as it will be a heck of a lot cheaper than having your speedo calibrated Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #326335 6th May 2015 2:09pm
miggit
Here's some interesting reading for you
http://www.thecarexpert.co.uk/how-accurate-is-a-car-speedometer/ Yesterday I couldn't spell Engineer... Today I are one!
Post #326339 6th May 2015 2:23pm
33CHINACARS
From an online tyre calculator
http://www.1010tires.com/Tools/Tire-Size-C.../255-60R18
If we use 255/60-18 as stock = 62.14 mph
255/50-20 = 62.12 mph - 0.03%
& 255/55-19 = 62.13 mph - 0.01%
If you can tell the difference of 0.02 mph your a far better man than I
Gary
Post #326366 6th May 2015 4:39pm
