Home > Technical (L322) > Sump plug won't come out
Page 1 of 4 1234>
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Tried to drain the oil & the sump plug won't come out. I undone it no problem, wasn't overly tight but it only unscrewed a few turns & is now loose but can't pull it out, it just spins loosely. Had to leave it on a slow trickle to drain out. 2004 RR 4.4 V8 Autobiography
Post #326448 6th May 2015 10:02pm
Can you get a knife blade or similar in behind the head of the plug to apply some pressure as your turn it. Might come out, but then you have the problem of getting it done up tight again Shocked .
Post #326452 6th May 2015 10:18pm
PaulM
I'll have to give it a try tomorrow, weather was horrible today so i left it. The oil has drained out now so maybe just do it back up. Question is why has this happened, never had a sump plug just get stuck. My thoughts were its stripped the thread but then it would just come out I would have thought. 2004 RR 4.4 V8 Autobiography
Post #326460 7th May 2015 12:00am
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
unless the thread has been formed from parent metal of the sump, it is possible that the weld nut with the thread has come adrift. May be a sump off to repair/replace. Big Cry
As said your issue is to retighten the sump plug............. Shocked Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #326469 7th May 2015 6:45am
DannyH
England 2002 Range Rover HSE 4.4 V8 Zambezi Silver
Stripped half the thread off the bolt, some thread on the inside of the sump is still fastened to the bolt and therefore the sheared part of bolt is just spinning and the remaining good bit of thread is stopping it coming out further?
Very unfortunate pal, probably won't fasten back in either so it will no doubt all have to come off (on the bright side, at least that gives you good access to clean all the gunk and old metal flakes out the bottom of the sump.) Dan
2002 Zambezi Silver
Men And Motors RR Quote - It's like having wheels fitted to your living room!
Post #326474 7th May 2015 7:56am
Sounds like a nightmare to me!!!
Can i suggest you remove the battery terminal whilst your dealing with this! Wouldn’t be the first to forget (or a family member) and start the engine with no oil in! Shocked Shocked Shocked
Does anyone on here know if the 4.4 petrol engine suffers any ill affects from being empty of oil?
Post #326488 7th May 2015 9:38am
PaulM
Craig, this whole car is a nightmare............ If it wasn't an Autobiography I think I would be looking at starting a Range Rover breaking business with this being my first victim😁
And Dan, I like your positive thinking....... I can clean my sump 😉............or buy a new one 😮 2004 RR 4.4 V8 Autobiography
Post #326492 7th May 2015 9:52am
Found myself whistling when i read Dan’s “look on the bright side” good old monty python Bow down Bow down Bow down Thumbs Up
Post #326494 7th May 2015 9:55am
PaulM
I hear that Craig Whistle 2004 RR 4.4 V8 Autobiography
Post #326516 7th May 2015 12:10pm
Mikey
All may not be lost
IIRC, the sump plug is screwed into the lower part of the sump, which is held in place with a ring of bolts. Not particularly cheap at £230 (minus any discount you may get)
Or, if you can do without the car, remove it, and take it to an engineering shop. They will be able to remove the plug, and drill/re-tap a new thread into it
Post #326524 7th May 2015 12:47pm
DannyH
to be fair guys, I've not even picked up my first ever RR yet (tonight at 6 - get in!) so I could be classed a naïve to the up and coming headaches that I'm likely to face! Dan
2002 Zambezi Silver
Post #326531 7th May 2015 1:16pm
Bryan N
England 2010 Range Rover Vogue TDV8 Santorini Black
Re: Sump plug won't come out
Paul,
Happened to me on a Jag sump. Undid it a couple of turns and then it would unscrew no further. I used brute force eventually to remove the plug but it stripped the threads out of the sump completely. The alloy sump had 'age hardened' and the threads became brittle so when at the previous main dealer service (I assume) some ape over-tightened the plug the threads sheared. I borrowed a Helicoil insert kit from a Jag Indie but made a bit of a hash of tapping the new threads 'square' (access in situ difficult on the Jag) so the sump plug never sealed completely afterwards without the use of sealing putty.
Tired of doing that at every oil change, I eventually used JB weld to seal the plug in place permanently and bought a vacuum pump with which to drain the oil thereafter! Smile
If you can re-tighten the sump plug on your car so that it seals properly, investing in a vacuum pump of the type they use on boat engines (e.g Pela 6000) to suck the oil out via the dipstick tube may be cheaper than removing the sump and repairing or replacing it.
Post #326538 7th May 2015 2:39pm
johnboyairey
if its stripped and wont tighten without dripping/gushing etc, then, you could just remove the lower sump, and fit a secondhand one. cant really be more than about £50 on ebay, if not too goosed around the threaded area, then drop it into a machine shop to drill out and fit a larger sump plug etc. plenty of larger ones available. its just a typical bolt really with a copper washer! could even be grease tapped from underneath.
interesting to know why it happed in the first place, but maybe there was an air tool used in its history.
Post #326558 7th May 2015 5:05pm
PaulM
Well I've been out today & it did tighten back up after I got it to catch. I would still like to know the issue but without removing the sump I won't really know. I'm not even sure if it's the correct bolt, do they have two washers or is it yet another bodge I've found? 😁
Post #326577 7th May 2015 8:09pm
Mikey
That's not the correct bolt.
I suspect someone previous has stripped the threads on the sump, and just mashed in any other bolt they had lying around...
Post #326584 7th May 2015 8:19pm
Page 1 of 4 1234>
