Home > Technical (L322) > Connector block ?
Try reducing the size of the image to 800x600 before uploading
Post #326989 10th May 2015 8:51am
does this on my iPhone too and the iPad.
It will add the pic to your gallery after a min or 2, then you have to go and copy and paste the link in the box under the gallery pic to the post.
works fine on the Macbook though. There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #326997 10th May 2015 10:17am
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
pics uploaded on laptop but still wont have it on the ipad
so any idea about this connector block hanging loose above peddles(RHD car)
Post #327069 10th May 2015 7:37pm
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
Could that be the electric trailer brake connector? Exclamation
EDIT - Except the L322 doesn't have one! I saw an article wiring one in under their but it was hard wired not loomed) Sorry.
Post #327152 11th May 2015 12:00pm
miggit
Does anything happen when you plug a diagnostic tool in........... only that's the only thing that I can think of that would not affect the car without being connected Yesterday I couldn't spell Engineer... Today I are one!
Post #327299 12th May 2015 12:16am
ironhorse
everything seems to work ok, just being lazey and hoping someone would know before i spent some time looking through rave
thought CTC may have had a bash at it
spare connector block what do you think its for craig Thumbs Up
Post #327509 12th May 2015 8:25pm
Zirconblue
Most of this post is about how to post pics so I've not read it all. Is there another connector like this on the other side? Are there any options your car doesn't have? It doesn't look like the obd diagnostic connector but it's in the right place for it.
Post #327516 12th May 2015 8:32pm
Mines got one to, pretty sure it's for the tow bar ECU thingy if you have the genuine towbar...
This thing....
 Pete
-Click here for Thread-
Post #327532 12th May 2015 9:05pm
Zirconblue
the trailer module mounts in the boot. But I think you're on the right lines with a similar style module. Tpms maybe?
Post #327551 12th May 2015 9:53pm
miggit
That module has the right connector interface, and when I said the OBD I did relies that it's not that type of connector, only thought that it might link the car to an OBD , ie plug into the OBD from the other side.
Suffice it to say that what ever it's for it is something that's either dormant or an add on, cos lets face it if it was important, the car would either refuse to work or the death Bong would be going into one along with the screen of Doom Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #327567 12th May 2015 10:25pm
Zirconblue
Fair point the obd connector might be a replaceable unit moulded to the cubby hole.
Post #327571 12th May 2015 10:34pm
ironhorse
Ok found out what it's for ,
In the electrical section of rave it says it's for a relay of some sorts,but the pic shows it not connected to anything so I'll go with that
And guess what: can't post a pic of the page with the ipatch Banging Head Banging Head
Gas board has dug up Virgin media cable so no internet on laptop so can't do it on there either
Cheers for the responce
Nige
Post #327614 13th May 2015 8:36am
Pepi
Remember reading something on one of the forums.
Remember reading something on one of the forums. But Seem to think it was about a P38 but sounds so alike it could answer this.
If I remember correctly it is a plug that is used by the transporter blokes when moving new vehicles from the factory.
It allows them to plug some sort of unit into the system that over rides and circomvents the functions that would interfere with the transporting process.
More than that I can't remember but it may be enough to jolt someone's grey matter. Idea Eddie the eagle watch out ๐Ÿ‘€
Post #329274 24th May 2015 12:18pm
