Home > My Range Rover > 2002 L322 Java black - photos
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
handig!!!! Pietertje.... Very Happy Thumbs Up Looks good
Post #325946 4th May 2015 1:42pm
Starberg
Sweden 2003 Range Rover Vogue 4.4 V8 Java Black
pietertje wrote:
@starberg @chex: I ordered a new key here: http://www.ecuobd2.com/trk-land-07-433. I then took this to my local locksmith to copy/cut my old-style BMW key into the new key. I then took the chip out of the old key and placed it into my new key... No need to re-learn the new key to the car because you are using your old chip. Pretty easy to do and the new key looks so much better...
Thanks!
How does the old chip align in the new case? Since the set up of the buttons is different from the old key. Also, you think this case will work as well? http://www.ecuobd2.com/trk-land-01-433 L322 Vogue 2003
Post #327020 10th May 2015 2:05pm
Weegie
There is a little slot down at the blade end and the chip fits into it. When I got the key there was a small piece of silicone in the slot which you remove and then use to secure the chip in place. It was just like a small bit of soft sticky rubber and can be easily replaced if your key comes without one.
Can't comment on the key in the link you quote. John
GAP iiD BT-Sold
Post #327039 10th May 2015 4:06pm
Robert
[quote=Niet helemaal juist, ik ben hier ook, en all heeeeeeeeeeeeel lang, sinds oprichting. Was eerst op RangeRover.net, en daarna hier[/quote]
Havank, Should have known.... Embarassed Dutch detective, have a few pocketbooks....
4 Hollanders and 3 is a crowd Mr. Green
Post #327060 10th May 2015 6:34pm
pietertje
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
@ starberg. Weegie is Right, there was a topic here with lots of photo's. I Think the key in the link should work as well since it's the same as the key in this topic http://www.fullfatrr.com/forum/topic8500.html 2002 L322 V8
Post #327063 10th May 2015 6:53pm
