![]() | Home > Technical (L322) > Air con compression only 9.45volts-SOLVED |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
Is the compressor clutch kicking in and out?
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
I have pretty much exactly the same problem at the moment - the red and blue wire supplying the clutch is getting 9.2 volts constantly, ignition off or on, ac button off or on. This caused my compressor clutch to burn out.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
The compressor clutch is fed from the Hevac ecu which is located behind the centre consol.
As noted above, that is the 3 pin black connector I was on about. |
2001 L322 Circuit Diagrams can be downloaded here:
William97841 Member Since: 18 Jan 2015 Location: Essex Posts: 151 ![]() ![]() ![]() |
Thank you guys for the response gonna test it tonight I'll keep you updated |
I tested the black while on the hevac unit I got 14v on the red and blue cable 0.025mv on the black cable on the black plug. At the end of the connector to the compressor while linked the red and black cable I then get 14v to the compressor. So I know the compressor has gone. It's just weird that I those reading on the plug at the back of the unit. I don't get 9.45 at the black plug on the hevac only at the connector to the compressor
It is the black (with grey strip I think) that links to the compressor clutch, the red and blue wire looks to feed power into the HVAC ecu/switch unit despite looking like the same wire at the compressor end. If you use a spare wire to bridge the red and black wires at the HVAC ecu end (with it unplugged) do you get 12v at the compressor and thus an engaged clutch? |
Yep I've bridged the red and blue cable to the black cable and got 14v to the compressor sadly compressor didn't kick or engage so I'm guessing I have the same problem as you kezbo1981 lol. So I think it's gonna need both hvac ecu and compressor. Because when I did disconnect that black plug the 9.45 v dropped out reconnected and 9.45v back so that's gone by the sounds of things.
When you say 14v I assume you had the engine running at the time?
Yeah sorry I had the car running because I wanted to see what voltage I was getting. Well I have the l322 td6 and I know I've gotta remove the bottom tray but I know the access is tight...so it looks like a fun job lol. Well £234 does sound appealing so might have to do that.
My new (used) HVAC ecu panel arrived today and..... same problem. Now I am confused as I may have bought a dodgy replacement panel or it might be another issue. However given everything is fine with the panel disconnected and with it connected I'm getting a constant 9v to the compressor I'm still of the opinion that the panel must be at fault. I need to do some more investigation, in the mean time if anyone else has any ideas please let me know! |
The other possibility is there's an issue with the clutch field coil, either short/open circuit or incorrect resistance (although if you've tried 12V directly to it and it's clicking in it's unlikely to be a problem).
