![]() | Home > Maintenance & Mods (L322) > Trickle Charging |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
I've got the Ctek7, never had a battery problem since, just use it with a ctek extension so it reached the outside power socket on my drive and then run it through the bottom of the tailgate rubbers and into the 12v in the boot , prob hook it up twice a month if not using the FF for a week or so |
Ethanicus Member Since: 23 Feb 2015 Location: Surrey Posts: 34 ![]() ![]() ![]() |
When using the supply feature on the ctek 7, I'm assuming you can leave the battery connected without issues. 2010 - Range Rover VSE 3.6 TDV8
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
That's a good idea Evro, that bag on the front seat |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
Yes no problems. John 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
I have a DIY solution in place right now !!
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 ![]() ![]() ![]() |
My Celica alarm used to drain the battery after 3 weeks of no use so I use a ctek msx5.0 and just leave it all the time on the winter setting. Got a2 meter extension and some extra cable, spliced together to make a7 meter cable and it reaches from my shed across the drive to the car.
Thanks, charged over night and sorted the issues I was having. Now leave connected to a baby check (0. ![]() 2014 - Defender 90 XS 2014 - Suzuki Swift Sport 2017 - GBS Zero 2006 - BMW Z4M Coupe (gone) 2004 - Discovery Landmark TD5 Auto (gone) 2008 - Defender 90 SX (gone) 2011 - Touareg Altitude (gone) |
