![]() | Home > Maintenance & Mods (L322) > Problem with gear box zf 5hp24 or tc |
pjpetit Member Since: 23 Jun 2014 Location: vernon Posts: 17 ![]() ![]() ![]() |
Ok nobody to help me |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 ![]() ![]() ![]() |
its difficult to understand your problem? your gearbox sounds like a bird ? I don't understand your photos either |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 ![]() ![]() ![]() |
My thoughts exactly Viper 😁 2004 RR 4.4 V8 Autobiography |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 455 ![]() ![]() |
Pierre-Jean
Bonjour ok
This is a slightly “loose” translation as parts of the source text are a little ambiguous …
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
could be the output bearing on the gearbox, if the prop shaft was slightly out of balance it would kill the bearing gradually. It might well be that it's just a co-incidence that it happened after the oil change. |
Is it easy to change? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1030 ![]() ![]() |
The transmission doesn’t have an ‘output bearing’ as such (other than a small needle roller ‘steady’ bearing in the F-brake drum) because there’s a transfer box between it and the propshaft.
Aren't there bearings on the transfer box where the outputs go to the prop shafts?
YES
There is no ball bearing on the transmission output - you must be looking at a diagram of a RWD version of the 5HP24 and not the 4WD version.
Isn't this just semantics? He said bearing not "ball" bearing? Bearing covers ball bearings, roller bearings (both straight and tapered) even white metal in the case of an engine. |
Sorry but i speak about this bearing g park lock and output rep 690
