Home > Maintenance & Mods (L322) > Wiper blade preservation in frosty weather
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Just a small point but when you get home each night from now until after easter and your car has to sit outside overnight, listen to the weather forecast and check that if there is frost forecast that before you lock the car up, switch off the auto-wipers function. Usually as soon as you put the key in and switch on, if the wipers are set to auto and there is frost or ice on the screen then the sensor will try to activate the wipers - if the blades are frozen to the screen then you will shorten their life and may also damage the wiper motor. I found yesterday that despite having Park Heat activated the wiper blades where still frozen to the windscreen and the auto wipers function was on............. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #32748 21st Oct 2010 5:56pm
dan_uk_1984
On mine if I leave auto wipers on you have to turn them off and on again every time you turn the car off. So you dont leave them on by accident from the day before and then go through a car wash the next day and rip them off I guess.
I wonder why/when they changed this...
Post #32750 21st Oct 2010 6:01pm
Tim in Scotland
both the RRSports that I have owned were the same, and if you engage reverse then when the front wipers come on then the rear one does too, damaging that! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #32751 21st Oct 2010 6:05pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
2010's onward are auto on if in than setting, unlike previous FFRR incarnations..... Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #32752 21st Oct 2010 6:06pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Time to buy shares in Wiper blade companies.
While we are on the subject of frost... Silicone spray for the door felts seals to.
Thumbs Up 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #32753 21st Oct 2010 6:23pm
Tim in Scotland
When I had my last FFRR back in 2003, after the first heavy frost the local dealer had to replace lots of door seals under warranty/ the VIP maintenance plan as the original design used to freeze completely to the body and opening a door ripped the whole seal off where there was contact. Didn't take LR very long to come up with a new design. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #32754 21st Oct 2010 6:35pm
Ditto for 02 model. Mine lives on Auto, just have to switch off and on again to get 'em working. .
Post #32803 21st Oct 2010 11:08pm
specman
Scotland 2016 Range Rover Vogue SE SDV8 Aruba
The first sign of proper frost and it will get tucked up in its purpose made wee hoosie aka the aircraft hangar as described by mates
Post #32806 21st Oct 2010 11:33pm
