Home > Maintenance & Mods (L322) > Bumper off - really????
Bomb Doctor
Hi All,
I've just got a quote for the LED ring & colour coding upgrade for my headlights. If done 'while you wait' the company said they would have to charge an extra 2hrs labour as, to get the headlights out, they needed to take the front bumper off...... I was under the impression that the lights came out with a few screws only?
L322 2007 SC.
Post #327671 13th May 2015 1:54pm
Zirconblue
I took the bumper off mine to do the electric fan the other day. The headlights definitely have mounting bolts at the bottom which I would think are only accessible with the bumper removed.
Post #327677 13th May 2015 2:28pm
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
Bumper does not need to be removed ! 2 scews at the top and one at the side then just pull it out. I had mine removed when replacing the bulbs takes about 2 minuets . They probably just say that to cover themselves as lots of cars will require the bumper off to get the headlights out
The front gill does need removed but that also takes minuets Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #327680 13th May 2015 2:33pm
Weegie
Don't know if there is any difference in MYs but I changed the complete nearside headlight unit on my MY2005 L322 in February without removing the bumper. It was straightforward. John
GAP iiD BT-Sold
Post #327681 13th May 2015 2:34pm
marky777
United Kingdom 2005 Range Rover Autobiography 4.4 V8 Bonatti Grey
Hi bomb d, would this upgrade be the same for my 05 ajv8 as your 07? Ithink they have the same front end? So is the conversion aimed at making it more like a 09 onwards style? And finally roughly how much and where? Sorry for all the questions but i like the idea of the led's Thumbs Up
Post #327683 13th May 2015 2:40pm
Zirconblue
that's a fair point, mine has the original type head lights with wipers. The facelift ones might be different.
Post #327684 13th May 2015 2:40pm
Weegie
Does this help?
 John
GAP iiD BT-Sold
Post #327685 13th May 2015 2:42pm
markcaughey
As said If the car has the standard 2007 front end then the only part that has to be removed is the grill, then its just 3 screws, 2 at the top and 1 at the side then just lift the headlight out . Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #327687 13th May 2015 2:47pm
Zirconblue
i see the lower bolts i mentioned are the wash/wipe mech mounting.
Post #327688 13th May 2015 2:48pm
Weegie
If you scroll down through the comments on the video link you will see that someone (Scottyav actually Very Happy ) has mentioned fitting LEDs. John
GAP iiD BT-Sold
Post #327689 13th May 2015 2:53pm
Bomb Doctor
Weegie wrote:
Does this help?
It does, to a point, but my MY is 07 and the lights are different.
Post #327691 13th May 2015 3:13pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I've got the 06 MY S/C and you don't need the bumper off as said above, take the grill off (three screws) being careful of the temp sensor wire and then there are three screws Philips #3 IIRC
Be a bit of a Censored changing sidelight bulbs otherwise Smile
Laughing
Steve
Post #327709 13th May 2015 5:00pm
