Home > In Car Electronics (L322) > 2010 - sat nav screen not turning on
andrew-a
Hi guys
2010 5.0sc. The sat nav screen does not turn on, even though the radio works fine. If I press the left hand side knob, the radio just switches on or off, but the screen itself does not turn all at all. Is it a fuse?
Thanks in advance
Post #327750 13th May 2015 6:26pm
ksskaret
Norway 2010 Range Rover Autobiography TDV8 Santorini Black
Have you checked your voltage, mine is doing a lot of "funny" moves if there is a low voltage. Try to charge it over night with a battery charger. Range Rover TdV8 Autobiography MY2010
Defender 110stw Td5 MY2006
Post #328202 16th May 2015 6:49pm
Might sound daft but have you tried unplugging the DVD , or checked the connections in the boot area ... ====================================
Post #328203 16th May 2015 6:54pm
andrew-a
Took it to a specialist today and they plugged in the diagnostics. Found no fault!
Then disconnected the battery to reset it, but that didn't fix it. I will charge the battery overnight and see tomorrow if that helps.
Thanks guys
Post #328216 16th May 2015 8:57pm
not your exact problem but you could try this,
http://www.fullfatrr.com/forum/post248527.html#248527 ... - .- -.
Post #328219 16th May 2015 9:05pm
andrew-a
Big Cry Big Cry Big Cry
Just been told i need a new header unit. Big Cry
Anyone got one for sale?
Thanks
Post #328461 18th May 2015 4:00pm
try site sponsor craig, CTC. ... - .- -.
Post #328472 18th May 2015 5:26pm
Zirconblue
You can also try these guys.
http://www.bba-reman.com/uk/index.aspx
They repair most vehicle electronic modules, they also have a part of their site dedicated to display units.
You can send off your current screen for repair. Or at the very least it says they'll buy your broken one.
I've used them for a couple of bits (went there in person) they seemed very professional.
Post #328503 18th May 2015 8:38pm
sako243
stan I'm sure you've heard this but you are the man! Bow down
I was just browsing the forum trying to find a solution to my nav rebooting (just started on Friday) and happened across your post. Worked a treat and thankfully will have the radio for the 1800 mile round trip to the highlands this weekend.
If I'm ever passing your way I owe you a pint or two. Ed
Post #328507 18th May 2015 8:57pm
Wink ... - .- -.
Post #328508 18th May 2015 8:58pm
andrew-a
Thanks - I have sent them an email but I guess I have to remove it first. How big a job is that?
Post #328818 20th May 2015 9:11pm
andrew-a
Thanks Stan but I can't find them on the list - any link? Thanks
Post #328819 20th May 2015 9:12pm
Zirconblue
The top dash cover has a few obvious screws holding it on and then the screen comes out through the top. I've not done it myself, but it doesn't look as bad as it first appears.
Post #328826 20th May 2015 9:52pm
Hi, what is it you need sir? How can we help?
Drop me a PM and i will sort in the morning sir Thumbs Up
Post #328837 20th May 2015 10:40pm
