Home > General > ive looked but no joy !!!
David
Spain 2007 Range Rover Vogue SE TDV8 Zermatt Silver
I have looked but i cant find so i am asking !!!!!! Rolling Eyes
How do you work the pre heater if you aint got the remote ? also does it work the other way i.e work the AC when its bloody hot !!!!!
Never used it didnt even know it exsisted !!!!!
Post #32792 21st Oct 2010 10:31pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
If it is a pre 2005MY and you have no remote, it will blow outside air in, on a timer. Thrilling eh Wink Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #32793 21st Oct 2010 10:33pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
No and no are the answers to those questions David.
You need the remote for the pre heater (if fitted) to work.
Air con compressor needs to be driven by the engine running to work.
Post #32796 21st Oct 2010 10:37pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
You don't need the remote...
But then you must pre-promgram the starting hour.
Post #32797 21st Oct 2010 10:39pm
SteveMFr
Site Sponsor
Has nothing to do with the MY or the remote.
Fuel burning heaters (FBH) were fitted to all diesels to augment the cabin heat as the motors are so stinking efficient that they don't produce enough waste heat to heat the large RR interior properly at colder temps (so there you petrol-heads Razz ). In addition, you could order a pre-heater function at the time of purchase for both the petrol and the diesel models. For the petrol, this meant that a FBH was installed, for the diesel it meant being coded (programed) to work with that function vs. just to augment the cabin heat. Setting the pre-heat function is done via the nav-screen or MID depending on what was fitted to the vehicle. In addition to all of that, a remote was available (not sure if it came 'standard' with the pre-heat option).
Theoretically it should be easy for the dealer to code a diesel for pre-heat function with the diagnostic computer. On the pre 2005MY's, the wiring is there for the remote receiver too (not sure about the later MY's) - so all you need are the pieces (which cost close to €1000 from the dealer...).
The FBH is exactly that - it burns fuel and gets hot, so no AC function. AC need the motor to be on to run the compressor, so the only pre-cooling function avail via the ventilation Thrasher mentioned.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #32811 22nd Oct 2010 8:00am
DMRR
No, the extra energy goes into that distinct sound of a tin of nails being kicked down the street instead, I know which I'd prefer Twisted Evil Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #32813 22nd Oct 2010 8:18am
SteveMFr
Site Sponsor
I know what you mean - as a life long gear head (orisit motörhead?) and Porsche nut I never thought my first turbo would be a diesel... Shocked
Then again I can't say that my TD6 has that diesel rattle at all - except for the first 2-3 times for a second or 2 on accelerating afer a cold start. Otherwise never. And what really convinced me (I might have posted this before) was when my wife calculated about 6-7 yrs ago that with the amount we drive and the 20% less consumption + 20% less diesel cost, we could finance a relatively new diesel RR from the savings alone! Said and done. Another one for the collection (4RR's and 3 non-RR's) Cool
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #32906 22nd Oct 2010 12:35pm
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I never thought I would buy a diesel either but I must say the TDV8 is a good car.
Thrasher I know what you mean, mine sounds like a tractor at idle and doesn't have the refinement of the 5L SC which I have driven for a few days.
I'm currently looking to buy a 2011 Range Rover and am hesitating between the new 4.4 TDV8 which has fantastic reviews and the enthusiast's but not so reasonable choice in the form of a 5L SC.
Thrasher would you go for the new 4.4 TDV8 if it doesn't sound like a tractor anymore?
Post #32965 22nd Oct 2010 7:32pm
