![]() | Home > Maintenance & Mods (L322) > Rear Window Trim alignment |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 ![]() ![]() |
You should be able to tap it back into the correct, central place. |
Mine was like that, tried tapping it with a block of wood to slide it along, never budged. Eventually cut off the excess with a junior hacksaw........very slowly and carefully. |
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
Yes it's the original, I just don't know why it's not even. Land Rover I guess |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
I slid mine off totally so you may be able to shift with some gentle encouragement There is a difference between knowing your sh!t and knowing you're sh!t
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
You might be able to move it, or it could be stuck with some of the glass sealant that Land Rover use to bond the glass to the door frame.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
I removed mine completely a few weeks back. At 1st it would not move so I sprayed wd40 along it and left overnight. With a lump of wood and some firm taps it started to move ok. After a clean and polish I like it better with the trim gone, a clean modern look all for free. Less is definitely more in this case
