Home > In Car Electronics (L322) > Poor FM reception L322 2007 TDV8 Vogue SOLVED
you havnt got a dashcam on the rear window perchance, cos that degrades the fm signal.. ... - .- -.
Post #328130 15th May 2015 10:15pm
Robgosty
No dash cam, it's not gonna be easy
Post #328132 15th May 2015 10:17pm
i'm running out of ideas now ..... ... - .- -.
Post #328133 15th May 2015 10:19pm
Robgosty
Needing someone in Manchester area who is a Range Rover audio expert Crying or Very sad
Post #328135 15th May 2015 10:21pm
Robgosty
Well you would not believe it, cause of problem was a f**k**g USB charger that I had plugged into power socket in centre cubby, Evil or Very Mad pure chance i found it, noticed that when ignition key was in accessory position, radio was fine, soon as it was turned to ignition (without starting engine) reception was poo and the same with engine running, I will be smashing offending article with a big hammer, just hope that this will help someone in same position Thumbs Up
Post #345787 3rd Sep 2015 4:22am
i was pretty close with my dashcam idea , glad its sorted. Thumbs Up ... - .- -.
Post #345792 3rd Sep 2015 7:35am
mzplcg
Oh cool, that's fixed my lousy FM reception in the work hack (Skoda). One of those cheapo dual USB chargers which I was using for the phone and TomTom. Said article now in the bin and a (hopefully) better quality one ordered from Amazon. Thumbs Up
Post #345796 3rd Sep 2015 7:51am
DK
United Kingdom 2002 Range Rover Vogue 4.4 V8 Santorini Black
I'm having a similar problem with mine, it's only happened since i put the new android head unit in so i'm thinking i did something wrong somewhere???
i get one radio station and that's all, the quality is terrible at high speed. until now i'd assumed the cheap aerial extension cable was to blame, but as soon as i get home i'll be pulling the USB cable out of the back just in case
Post #349886 29th Sep 2015 4:30am
lee37Vernon
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Same here, wired in a nice little 3amp USB charger under the dash top, coming out right under phone cradle.
Great using Internet radio and maps on a long trio but totally screw's most FM stations up...
Cheap s@#t , what do they say, buy quality, buy once.. Neutral 2003 4.4 Adriatic Blue FF
Post #350525 3rd Oct 2015 9:04pm
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
My FM reception on some stations has just gone very poor when I switch the rear screen heater. I have a sub charger plugged in but as far as I recall I haven't used the heater with plugged in until the last couple of days when the temp has dropped. I will have to check this and see if that's the cause.
Post #350527 3rd Oct 2015 9:33pm
tvrforever
Anybody got a 'known safe brand & model' of USB charging adapter then?
I've just had the exact same issue but with the DAB radio reception being destroyed through the use of an "Archeer 4.8A Mini Powerful Dual USB Car Charger" ( https://www.amazon.co.uk/gp/product/B01CCMEC2U ) in the rear of the centre cubby. Plug it in and no DAB, remove it and all ok.
Currently I'm using a "TomTom Universal High-Speed Multi-Charger" ( https://www.amazon.co.uk/TomTom-Universal-...B004SH3ERC ) as an interim - but it's a bit bulky...
Post #384925 2nd May 2016 6:37pm
