Home > Maintenance & Mods (L322) > Suspension air reservoir
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I was just planning the repair of my corroded rear wheel arches when I spotted the terrible state of my air resevoir.
I shall get onto Dan for a replacement and have done a search on the forum for tips on replacement, especially regarding the connectors at the ends, but found nothing.
Has anyone any experience of swapping these and is there anything I should do at the same time.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated :mrgreen:  2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 L322 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #328310 17th May 2015 4:24pm
These might help you. Thumbs Up
Post #328326 17th May 2015 6:32pm
It is a silly fiddly job! So many things to remove in order to get at it, plus the disconnection of all the pipes to all the corners.
Make sure you have enough height below the car to drop the tank cover, and take special care removing and replacing all the pipe connections on the block valve, e.g. not cross threading any! it is a fiddly tight place to get them all back on.
The valve block might come away from the rubber mountings on the reservoir, you will need to use some creativity and extra special glue to stick it on to the new one, unless you can get some new mountings from Duckworths.
I had the valve apart whilst it was off, no problems with mine in terms of corrosion inside, others have had much worse. .
Post #328328 17th May 2015 7:07pm
RRBlue
Thanks chaps. Tips well received.
The current resevoir is peppered with holes with the deep blisters. I hope it holds out for a few weeks before I can get time to do it.
Will report back. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #328331 17th May 2015 7:21pm
heppsen
Germany 2012 Range Rover Vogue TDV8 Santorini Black
At this stage of corrosion, I would strongly recommend checking the brake lines underneath the cover along the left hand sill ( thats where they are on a LHD vehicle)
Regards
Heppsen 2017 MB V-Class
2016 Q7 (gone)
2012 FFRR TDV8
2012 Smart Pulse Turbo
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #328359 17th May 2015 9:38pm
^^^^ Agree!
That said, I am surprised to see corrosion on the reservoir. Mine (if original on an '02) is (or appears to be) of galvanised construction and not a sign of rust anywhere.
Brake pipes were in a state though Wink .
Post #328362 17th May 2015 9:48pm
RRBlue
Funny you should mention the brake lines. I inspected them last year and decided to invest in genuine new rear lines that run down the nearside. I have still yet to work out how to fit them. Especially the line for the offside rear as it is in one piece and unlikely to survive the process of threading it through and across the rear axle. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #328369 17th May 2015 10:20pm
RRBlue
This was not galvanised as far as I can tell, just painted black. The new one will get some extra treatment. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #328370 17th May 2015 10:22pm
The one piece pipes should go in OK if side steps are removed, tank cover, rear wheel and a reasonable clearance below. I put a joint in (protected by tank cover) to overcome this. Check wiki. .
Post #328383 17th May 2015 11:02pm
Zirconblue
Joe90 wrote:
^^^^ Agree!
I wouldn't be surprised if they rust from the inside out. I think there is a drier filter on the compressor but i doubt it keeps all the moisture out.
Post #328389 17th May 2015 11:33pm
RRBlue
Perhaps it's time to take a look at the drier as well. I will investigate. I seem to recall some good videos on this. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #328399 18th May 2015 5:49am
Yep, dismantling the compressor is a warm, inside, kitchen table job, be prepared to catch all the little silica beads Thumbs Up .
Post #328417 18th May 2015 11:22am
RRBlue
New air receiver fitted. Not too bad really. All the advice from the forum had lowered my expectations. New receiver from Dan fitted and painted with stone chip. Replaced all the nuts and bolts with new and kept the side step off so that I can treat the wheel arch rust.
Here is the delivered item before tone chip treatment next to the old one.
Suspension seems to be working, although it is currently giving me 'lifting slowly' message. Have checked for leaks at the air connection but seems ok, will give it some time to settle as I have only run it for about. 5 mins on the drive since the replacement.
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #333877 22nd Jun 2015 11:46am
