![]() | Home > Technical (L322) > Air con compression only 9.45volts-SOLVED |
| Weejock Member Since: 30 Dec 2011 Location: UK Posts: 419
While ripping out an old hands free kit from the console I've done some testing on my working A/C (fingers crossed I haven't just jinxed it) so hopefully you have a reference of 'good' figures to work to.
See my above post about testing the compressor clutch coil, you need to disconnect the connector to the ECU in order to get the correct measurement of the coil by itself. With ECU still in circuit you will get around 16Ohm. Shorting the pressure sensor has just effectively told the ECU the pressure has shot up and out of range (>33bar). The fans have come on correctly to try and bring the pressure down but the compressor clutch won't engage as it thinks it's over the limit. Try measuring the resistance as I have done above or voltages (more tricky to do on the connector, easier to pierce the cables concerned). Just out of interest is your blower working correctly? |
| kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335
This is really interesting, thanks. when it's not hammering down outside I will go out with my multimeter and do the same measurements. Is it Easy to take the shell off the blue and black connectors? |
Yes, the outer shells are held on by a single tab on one side, you just need to prise the outer shell over it and the connector slides out. If you look at the blue connector first it's easier to see as the shell is blue and the connector white.
De-shelling the multi plugs is really easy isnt it! thanks for telling me how. So i have been out with my multimeter, here are the results next to yours (yours in italics, my results in red):
Those results look OK.
| William97841 Member Since: 18 Jan 2015 Location: Essex Posts: 173
Hi so I tried a few of the tests but I still was stuck so I took it to s air con speacialist they tested it and now sucked it and refilled it but now I get 14.445 with engine running for a few seconds then back to 9.45 for a few seconds then back up to 14.45. So now I'm gonna get a nissens compressor and get it refilled and see what happens. I'll keep u up date soon. If I can't do it then it's time for windows open lol |
So does that point to some sort of dodgy pressure sensor? |
Taking it a Land Rover specialist in air con see what they say. But still think it's the compressor |
Let me know how you get on and if they find a solution! |
Is the compressor clutch engaging when you are getting 14.4V?
Any update on this? |
Hi guys just a quick update sorry for the delay I changed my compressor first and also changed my condenser and now everything works including the cooling fan. Which does come on when the air con is active. So all good now. Thanks guys for all your help |
I've solved mine too, things I have learnt:
| All times are GMT |
