![]() | Home > Maintenance & Mods (L322) > "stretched" Tow Ball Protection Plate |
Blimey... |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136
That's a few spacers |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277
Bringing it out further from the bumper reduces the amount of vertical load you can have on the tow ball. So i would imagine they've kept it close to keep the vertical load limit as high as possible. |
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
Yep, I have the MaxRaxx as well but when I measured it from the centre line of the rear wheels the extra 36mm made a massive 2.97% difference so the maximum vertical load of 150KG (250KG if you reduce the max load in the boot by 100KG) was about 4 kilos. Since the caravan hitch and the one on the Ifor Williams are max rated at 100KG it doesn't matter.
| devonchilliman Member Since: 06 Jan 2015 Location: Devon Posts: 348
Oh and only one spacer used @dom Last edited by devonchilliman on 19th May 2015 8:57am. Edited 1 time in total |
Cliff, did you just accuse me of owning a tin tent sir |
Would I ever...just the likes of Dom |
Like ide get the time to use it |
Hey, now then.....I've got an Ifor as well |
It "tis" yes sir... |
So that's 3 reasons to visit you now |
Indeed... (but i forgot the other two) |
| All times are GMT |
